Old 02-14-2015, 03:03 PM   #1
trb97
Getting ready for disk conversion... question.
Hello,
I'm gearing up for a front disk brake conversion on my 63 gmc. I purchased
A conversion kit from performance online. 6lug 2.5 inch drop with booster. I also bought the new brake lines. I need to limit the downtime for the truck because I run my business out of it.
Is there anything else I should get before I start? Any special tools needed?
I searched but was unable to find anything.
Thank you!
trb97 is offline   Reply With Quote
Old 02-14-2015, 03:23 PM   #2
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Getting ready for disk conversion... question.
Lots of info on that
check the FAQ section 60-66
It would certainly be a good time to do upper and lower ball joints
and evn tie rod ends
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-15-2015, 01:19 AM   #3
Captainfab
60-66 Nut
It's hard to say without knowing more detail on just what is included in the kit you bought. Also a '63 GMC should have a hydraulic clutch. That will have to be addressed when adding a vacuum booster and disc/drum master cylinder. I do make a booster bracket just for the '60-'62 Chevy's and '60-'63 GMC's with the hydraulic clutch. Or has your truck been converted to an auto trans? I also make booster brackets for that application that will cover up the extra hole in the firewall. There are links to the for sale threads in my sig line \/ \/ \/
Old 02-15-2015, 07:22 AM   #4
luvbowties
luvbowties's Avatar
Smile Re: Getting ready for disk conversion... question.
I think if I were just beginning forum-explained work on a GMC (or Chevy, too) of our 60-66 years, I would earmark this link in big letters on my desktop: >> http://www.fullsizechevy.com/forum/a.../t-521160.html <<. Has lots of research links, by project type, listed that give you invaluable info on "what all fits", where to find parts, descript.of kits--just take a quick look & I think you wil quickly agree to keep this link close at hand for many--if not all--your anticipated projects. One of our members, Woogeroo, looks to have spent countless/valuable hours that contribute heavily to the compiled links AND information AND how-to's--very well organized by truck year, model, etc.
Good luck with your build, and I hope this will help you enjoy your build.
Sam
luvbowties is offline   Reply With Quote
