Old 02-14-2015, 08:44 PM   #1
Tilt
Rear axle RPO code G01
I was pulling the brake assembly and steering column out of an 85 Custom Deluxe today. I'm kinda sorta looking for another rear end to go in my 86, if I just happen to run across a good one while doing the LS swap. I checked the SPID and the RPO code was G01-Rear Axle-Standard. It could be GQ1, but I think it's G01. What would Standard refer to? I'm assuming I wouldn't be lucky enough for this to be a 3:73 or 4:10 posi unit.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 02-15-2015, 07:25 AM   #2
chengny
chengny's Avatar
Re: Rear axle RPO code G01
Nope, you're not lucky enough. No G01 code that I could find. But I quickly stopped looking when I saw this:
As far as - what is the Standard Ratio? IDK.
But, because there are quite a few 3.73 rear axles listed (none of which were mentioned as being Standard), it would be safe to assume that Standard does not equate to a 3.73 gear ratio.
Here the link to a good, complete listing of RPO codes:
http://www.rpocodes.com/GM-RPO-codes...GthroughM.html
chengny is offline   Reply With Quote
Old 02-15-2015, 10:53 AM   #3
greg64
greg64's Avatar
I'm thinking it's 3.42 because 3.42 was very common, and it's not on the list.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-15-2015, 12:13 PM   #4
Keith Seymore
Keith Seymore's Avatar
It's GQ1 = standard ratio.
I need to know what trans in order to tell what ratio that was, but it's going to be either 2.73, 3.08, 3.42 or 3.73.
If an optional ratio was chosen the SPID will show the actual RPO and description (ie, GU6 = 3.42; GT4 = 3.73). For a base axle it only shows the RPO as GQ1, since it varies.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-15-2015, 06:18 PM   #5
Tilt
Transmission code is MX1-3 speed automatic.
'85 GMC short bed.
Old 02-15-2015, 06:30 PM   #6
Tilt
From the chart above, looks like it's a 2.73. Well the search continues.
'85 GMC short bed.
