02-14-2015, 08:54 PM | #1 |
1-ton Longhorn vs 3/4-ton
There's a thread about 1-ton Longhorns (now I kind of wish mine was one, but I'll be ok), and it made me curious about what the difference is.
My 2500 GMC (think C30 Longhorn) uses, I think, 1-ton rails, has the Dana 60, same rear suspension. The only difference I can think of would be the front control arms and spindles. If that's the only difference, I can't imagine why they bothered to make both variants, so I must be misunderstanding something. Can someone learn me all about this? I've been working on one for three years, you'd think I'd know! Longhorn man?
02-14-2015, 09:48 PM | #2 |
Vintage 4x4s
Re: 1-ton Longhorn vs 3/4-ton
Springs and brakes were different. Correct on them both using 1 ton frames.
The offering of HD 3/4 and 1 tons that share the same frame isn't unusual. The 01 up 2500hd's use 1 ton frames and axles, yet they still offer a SRW 1 ton.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-14-2015, 10:49 PM | #3 |
Thanks! Weird though. Seems odd to carry a completely different SKU (or whatever they call a model variant) just for springs and brakes and control arms.
I guess I'm more surprised they didn't just build all Longhorns that way, but they knew their business. To wit, in a '69 Impala if you had a 6-banger Biscayne you only got one upper control arm (on the rear obviously!).
02-14-2015, 10:57 PM | #4 |
My Longhorn C20 has an Eaton under the rear, could the Eaton vs Dana be another difference?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-14-2015, 11:51 PM | #5 |
I think 2500 in GMC-speak is 3/4 ton. 3500 is 1 ton.
02-15-2015, 12:25 AM | #6 |
Wouldn't all C/30 and C3500 Longhorns have HO72 rears? I've only seen Dana 60s used as 3/4t rears.
02-15-2015, 12:59 AM | #7 | |
Did they make a 67-72 coil spring version 30 with overloads? |
02-15-2015, 01:03 AM | #8 | |
02-15-2015, 09:04 AM | #9 |
No and No. All 30 series had leaf spring rear. So, since all Longhorns are on C/30 frames they are all leaf spring
02-15-2015, 07:38 PM | #10 |
Did all C30s have dual rear wheels? If so is that the rear end difference? HO52 is SRW and HO72 DRW?
02-15-2015, 07:51 PM | #11 |
No, there were single rear wheel C30's. For example, take the Longhorn, in 67-72 you couldn't have a DRW with a bed, so if there was a one-ton Longhorn, then you definitely had a SRW C30.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-15-2015, 07:56 PM | #12 |
Vintage 4x4s
It has been discussed before but I cant point to a thread. At least, the brakes are different between the HO72 and HO52. I think thats it for differences but can't confirm.
02-15-2015, 09:16 PM | #13 |
Brakes and bearings are different. Basically, the backing plates-out are different
02-15-2015, 09:27 PM | #14 |
I thought there was a support bolt or something that all HO72's had in the carrier that only a few HO52's had?
