Old 02-14-2015, 10:13 PM   #1
Hugh in NC
Hugh in NC's Avatar
Door Bumpers
I see this door bumper listed for a '63. My truck does not have these bumpers. Should it have these bumpers, where do they go and how many per door? Can someone post a photo showing location?
Thanks for the help,
Hugh
Hugh in NC is offline   Reply With Quote
Old 02-14-2015, 10:16 PM   #2
Andice
Andice's Avatar
Re: Door Bumpers
Here is where they go on a '64 GMC
Andice is offline   Reply With Quote
Old 02-14-2015, 10:19 PM   #3
Hugh in NC
Hugh in NC's Avatar
Re: Door Bumpers
Thanks for the quick reply. I guess the previous owner filled the holes. I should be able to get them close enough from your photo.
Hugh
Old 02-14-2015, 11:41 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Door Bumpers
on my 60, and 61 they are up here:
Old 02-15-2015, 12:44 AM   #5
AcampoDave
AcampoDave's Avatar
Re: Door Bumpers
My buddy's' 63 has no holes either.
AcampoDave is offline   Reply With Quote
Old 02-15-2015, 12:54 AM   #6
Micmac
Micmac's Avatar
Re: Door Bumpers
Nor does mine.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 02-15-2015, 12:49 PM   #7
spookylynx
spookylynx's Avatar
Re: Door Bumpers
mine had the holes, but they were too small for the reproductions. It's no big deal, just drill some new ones and push them in.
spookylynx is offline   Reply With Quote
Old 02-15-2015, 01:06 PM   #8
Andice
Andice's Avatar
Re: Door Bumpers
The repros come in two sizes: one for big holes and one for small. My truck (a '64) uses the ones for the smaller holes.
Old 02-15-2015, 01:44 PM   #9
61K10
61K10's Avatar
Re: Door Bumpers
my 61 had no holes and weren't filled either. anybody really know about these?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-15-2015, 08:44 PM   #10
spookylynx
spookylynx's Avatar
Re: Door Bumpers
yup... at least from LMC the ones for 60-63 are the small ones and the ones for 64-66 are the big ones. Too bad my 65 had the small holes. But it was nothing a Step ream couldn't fix.
Old 02-16-2015, 01:40 AM   #11
bhc41051
bhc41051's Avatar
Re: Door Bumpers
x2 on LMC having the right ones, I think this is the ONLY thing they got right.
bhc41051 is offline   Reply With Quote
Old 02-16-2015, 01:27 PM   #12
1strong63
1strong63's Avatar
Re: Door Bumpers
my 63 do not have holes too and i don't feel that they have been filled. i very closely look and cannot see a welded/grind area.
1strong63 is offline   Reply With Quote
Old 02-16-2015, 08:34 PM   #13
Hugh in NC
Hugh in NC's Avatar
Re: Door Bumpers
I thought I had missing door bumpers but sounds like maybe not. I am in the middle of the Honda weatherstrip install and will wait until I finish and see how the doors close. My truck was made in Baltimore. I wonder if assembly plant determined if the truck had door bumpers?
Thanks for all the replies,
Hugh
Old 02-16-2015, 11:24 PM   #14
63burban
Chevy addict
Re: Door Bumpers
The "V" shaped guide in the door jamb below the latch takes care of the no bumper situation
63burban is offline   Reply With Quote
Old 02-17-2015, 03:23 PM   #15
luvbowties
luvbowties's Avatar
Smile Re: Door Bumpers
Hugh
Pardon my hijack, but what's the reason for using Honda weather strip? For easier closing? Do they make door closing easier, from some of those who have used them, or is this new territory? Which Honda w-strips are the ones to use? Thanks for answers & info. Please report back how well they work. My pass door is fine, but my driver's door is a 'slammer', on a '66 sbss, & I highly dislike it!
Thanks,
Sam
luvbowties is offline   Reply With Quote
Old 02-17-2015, 08:11 PM   #16
Jeff La
Re: Door Bumpers
Thanks,
Sam
Here's the full explanation http://67-72chevytrucks.com/vboard/s...d.php?t=617703
Jeff La is offline   Reply With Quote
Old 02-17-2015, 11:06 PM   #17
jonzcustomshop
1961 crewcab
Re: Door Bumpers
I took a look at a few of my trucks, looks like all the 63's did not have them, I have 3 chevs, and a gmc...
I have 1 60 with them, and 1 61 with them, and 2 61's without....(all chevys), and 1 61 gmc with...
I have a 66 gmc with none in the lower spot, and a 66 chev with them in the lower spot...
Old 02-18-2015, 05:14 AM   #18
65chevysub
65chevysub's Avatar
Re: Door Bumpers
What's the easiest way to install the bumpers? I was thinking a mild soap and water solution or rubbing alcohol like when installing handlebar grips.
65chevysub is offline   Reply With Quote
Old 02-18-2015, 09:14 AM   #19
63burban
Chevy addict
Re: Door Bumpers
Spray glass cleaner around the hole and on the rubber and twist it in
Old 02-18-2015, 11:20 AM   #20
Micmac
Micmac's Avatar
Re: Door Bumpers
Back in the day when putting tight handlebar grips on my old Indians after a rebuild, I read somewhere to use hairspray, I tried it and it worked great. It was the old aerosol type. I am sure this would work with this application as well.
