Old 02-14-2015, 11:30 PM   #1
chevyman70
5.3l Mystery vacuum leak!
So, I've had a problem with my 5.3l swap. It now reads it has a vacuum leak and codes p0171 and p0174 appear. I replaced MAF, intake manifold gasket, fuel pump, new filter, valve cover gasket, pcv, pcv grommet, and replaced vacuum hoses. Ltft reads 10-18% during iddle on both banks, 25% during acceleration and part throttle. When I plug the PCV, the fuel trims drop to 0% during idle, part throttle, 10% during acceleration. So my question is, what would cause the pcv to act as a vacuum leak?
chevyman70 is offline   Reply With Quote
Old 02-14-2015, 11:46 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 5.3l Mystery vacuum leak!
If its truly a vacuum problem, it might be worth taking some starting fluid and spraying the intake manifold. On occasion, the plastic manifolds can crack if they were dropped, or torqued down really hard.
Otherwise, its possible that a tune related issue is triggering what seems to be a leak, however you have to troubleshoot it down to that point.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-15-2015, 12:04 AM   #3
chevyman70
I have done that as well. I don't see/hear any difference. I have even tried two sets of gaskets, felpro, and victor reinz. same results. I even replaced intake manifold bolts.
Old 02-15-2015, 12:19 AM   #4
chevyman70
if the pcv is a controlled vacuum leak, how does the computer know its a vacuum pulling from the pcv?
Old 02-15-2015, 12:28 AM   #5
mattcrp1
mattcrp1's Avatar
If you have access to a scanner that will allow data logging, monitor ltft, stft and o2 while spraying down the suspected area's, as well as clamping the pcv line. This can give an instant reading when the condition changes.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-15-2015, 12:29 AM   #6
ls1nova71
ls1nova71's Avatar
I have heard there was a problem with the valve cover, the one with the tube in it not the one with the PCV valve, but I dont recall the specifics of I, but it had to do with the baffling in it not sealing correctly and replacing the valve cover would fix the problem. Might try looking it up, not sure if it was a factory service bulletin or not.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-15-2015, 12:30 AM   #7
chevyman70
ill try that
Old 02-15-2015, 10:47 AM   #8
ls1nova71
ls1nova71's Avatar
Im an idiot.... I really shouldnt post things when its late and I'm tired. Thinking back today, I think that was the fix gor a buddy's truck that was using a lot of oil. Sorry.
Old 02-15-2015, 08:34 PM   #9
chevyman70
After spraying several cans of carb/choke cleaner, I did not notice any changes to the LTFt, STFT, or significant change to O2's. I drove it around with the pvc plugged, and I noticed the LTFT would jump to 25% just by slightly taping on the throttle. As soon as i let go of the throttle, it will drop around 8-10%. Stft, starts going to the negative as soon as I let go of the throttle.
Old 02-15-2015, 08:58 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Since your in Cali, are you running an EVAP and is it plugged in? The EVAP system is a giant controlled vacuum leak.
Old 02-15-2015, 09:39 PM   #11
chevyman70
the Evap is removed.
