Old 02-15-2015, 03:23 PM   #1
hanly2
Cab patch panels
I need to replace some panels on my cab like a cab mount, corner, rockers. What is the correct order to replace these in? I don't want to just start cutting and mess it all up. I already have the bed off, should I take the front clip off also? Or do I need the fenders on to line up the rockers?
hanly2 is offline   Reply With Quote
Old 02-17-2015, 01:54 PM   #2
hanly2
Re: Cab patch panels
Can anyone help me out with this?
Old 02-17-2015, 02:03 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You'll need the fenders and doors to help align the rockers. I would do cab supports first, then corners, then the rockers. But you'll probably need to somewhat tack the rockers in when doing the corners at some time to help line everything up. It's the way I plan on doing mine when I start cutting. But I don't need to do my cab supports.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
