Life is Good !
stock or aftermarket ?
I was out saterday at a buddy's shop. He was working on a chevy truck. to be honist did not pay attention to the year.
![]() ![]() Anyway the had these motor hold down things. I have never seen anything like that before. I was wondering if they were stock of aftermarket? thanks for the help. P.S. sorry for the pics. did the best I could..
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
Life is Good !
heres another pic,
its all about the +6 inches
Stock.
I have the dealer recall paperwork. |
Life is Good !
was it an option? or was it on all the trucks?
Here is the front...
And the back.
This was a safety recall on all trucks for 60 - 72 I think.
The motor mounts in our trucks were not good enough against the torque, and they could seperate. Also, in the 70 and older trucks, they had the throttle rod instead of a cable. This only made things worse. So they sent a re-call to all owners and a few came in for it. Some were chains, others were cables. Most were wrapped around the driver's exhaust manifold and then the upper a-arm. The pictures you have seem to show one on the power steering pump, and another on the A/C pump on the other side of the engine. Also, I think I see a bracket of some sorts on the frame instead of just going around the upper A-arm. If this is what I see, then some one either paid for the mod, or did it himself, or possably had connections at the local dealer and had them take special care of him. I can not see a dealership doing this much work when they are not getting paid for it. Esp doing twice the amount of work that was needed. |
![]() Join Date: Jul 2003
My 1970 never received the limiters.
This was a big problem with Chevys 1958-1970 cars also. |
20' Daredevil (Ret)
![]() Join Date: May 2003
I once owned a 65 Corvette 327/365 which was pretty quick. A motor mount failed, and when that thing stuck wide open in 1st, it would get your attention in a hurry!
#10 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
This recall applied to cars, too (although the letter posted here doensn't refer to them). I remember my Dad telling me that he had two different cars that he got letters on. I forget whether he actually took them in to have the restraints put on or not. I do remember him saying he had to chain one engine down.
Apparently, this problem deosn't exist any longer. What changed?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
![]() Join Date: Aug 2001
![]() ![]() GM CHANGED THE STYLE OF MOTOR MOUNTS TO THE (CLAM SHELL STYLE OF MOTOR MOUNTS) ON TRUCKS IN 1972. A MUCH BETTER & SAFER DESIGN.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#13 |
![]() Join Date: Oct 2002
ive seen some of the kits nos on ebay a few times.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
#14 |
Cool, I have never seen nor heard of the set up...except for what I described.
Either way, it is the recall. |
#15 |
can someone give me a reference spot on these photos? i am having a really tough time understanding where they were taken from (from what vantage point).
is he looking down on the engine? or from the side of the engine? is he standing over the front grill taking the pic? or is he leaning over the front side fender? i *think* i see a valve cover in the second pic. but i need a bit of guidance. help me pls! thanks! ![]()
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
#16 |
Back drivers side of the engine on the left side of the pic, on the right side you can see the linkage for the autotranny, and the master cylinder lines.
#17 |
so what happens if u want new motor mounts and have those in their. jack up the motor?
70 longbed 496/th400/Ford 9" |
