Old 02-15-2015, 06:52 PM   #1
cfan10
cfan10's Avatar
Cool redish color in radiator?
Anyone know what could cause antifreeze in radiator to be almost like a salmon color? Went to check the level and its a weird color asked a mechanic and was told previous owner probably added some sort of stop leak additive. It does not look like rust. Any advice is greatly appreciated. Thanks in advance.
90 350 TBI
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 02-15-2015, 06:53 PM   #2
cfan10
cfan10's Avatar
Re: redish color in radiator?
Is the additive dangerous to other things, seems like a bad idea to do this.
Old 02-15-2015, 07:15 PM   #3
80SPORT
80SPORT's Avatar
Likely the previous owner switched to long life coolant such as Dexcool.As long as system was flushed you should have no issues.If you have to add coolant be sure to use a universal type and not the green ethylene glycol.
80SPORT is offline   Reply With Quote
Old 02-16-2015, 02:42 AM   #4
mattcrp1
mattcrp1's Avatar
Is it milky as well? Could be trans fluid mixing if it has a trans cooler in the radiator.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-16-2015, 03:22 AM   #5
andrewmp6
Stop leak is a bad idea most use it to fix a leaking head gasket,And its good at stopping up water passages and sometimes radiators.Look down inside the radiator does it look nasty and sludge or clean and smooth?
andrewmp6 is offline   Reply With Quote
Old 02-16-2015, 04:27 AM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
Dump and flush, refill with green
Malo83 is offline   Reply With Quote
Old 02-16-2015, 09:47 AM   #7
cfan10
cfan10's Avatar
Not milky. That was my first thought about trans fluid mixing. I'll get a closer look today. Thanks guys!
Old 02-16-2015, 11:05 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
sounds like a stop leak or a mix of old and new type of rad fluids.
Flush ASAP
not likey tranny fluid,I'd think the higher pressure would blow the rad cap, no?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
