02-16-2015, 09:41 AM | #1 |
DBW Gas Pedal Adapter bracket
I build a DBW pedal adapter bracket for the 67-72s
(here: http://67-72chevytrucks.com/vboard/s...d.php?t=652799) And I was wondering if there would be much interest here. The bracket would be bolt in and use the 03-08 Truck/SUV pedal like in the picture. Let me know. R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-16-2015, 11:18 AM | #2 |
Re: DBW Gas Pedal Adapter bracket
I would be interested.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
04-14-2015, 03:04 PM | #3 |
I'm gathering parts my swap now and would definitely be interested in something like that.
04-14-2015, 08:02 PM | #4 |
Definitely interested. Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
05-24-2015, 08:36 AM | #5 |
I think my current 67-72 pedal bracket will work on the 73-87 with just redrilling the pedal mount holes. Who wants to try it?
05-26-2015, 08:04 AM | #6 |
I'll ship it free to someone if they will take pictures of any mods they have to make....
05-26-2015, 09:27 PM | #7 |
Rob, I'm your man for this!!
05-27-2015, 09:13 AM | #8 |
I have wondered before about a part like this for those who do the ls swaps.I hope you get it to work and get them out their for people like us.
05-27-2015, 04:32 PM | #9 |
Slots go on anything!
I am finishing one up now. I used a flat plate, but would be happy to be the guinea pig. If you don't have any takers, send it my way.
1974 Jimmy- 5.3/4L80e/NP241 |
05-27-2015, 05:54 PM | #10 |
I bought 1 of the first brackets you made to try in my 88 crew. If 73-87 are like mine they will just need to be redrilled. I took my pedal out to get it done but haven't got to it yet.
05-27-2015, 05:56 PM | #11 |
The 1 I bought was for the corvette pedal.
05-30-2015, 11:23 AM | #12 |
PM sent Rob!
06-20-2015, 05:11 PM | #13 |
Hi Rob,
Pedal installed and it feels great, much better than the stock truck pedal. I know you told me before, but could you please tell me again what wires to switch so I can use the vett pedal now? I have a 2011 5.3 Thanks again! |
06-21-2015, 08:32 PM | #14 |
Hi Rob,
I switched out the brown and black/white wire and the pedal works perfect. Soooooooo much better than the stock truck pedal. Thanks!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
06-21-2015, 10:44 PM | #15 | |
Thanks for the pics Ben! Glad it all worked for you.
06-23-2015, 04:16 PM | #16 |
Hi Rob,
Saw your bracket and also wondered if it would work on the squarebody styles. I am in process of swapping a 2003 Tahoe 5.3 into an 85 C10. From my basic fitting of the truck DBW pedal into the 85 cab, it seems that it would fit but the DBW sensor/mount would be VERY close to the steering column. But pedal itself pretty much where the original one was. However, I noticed that by moving the new pedal there the DBW sensor was right in line with the brake pedal arm. This would probably be no big deal under normal circumstances. (i.e. normal braking) But I worried if the brakes were to go out or as they were pumped to the floor for bleeding, that the arm could contact the DBW sensor and possibly break it. Has anyone trying the bracket noticed if the sensor will be in line with the brake arm or not? Just wondering. Thanks.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
01-07-2016, 12:01 PM | #17 |
For all of the guys looking for a pedal bracket to work with the 73-87 trucks, here's a thread that has some great info in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=692222 http://www.hotrodlane.cc/Streetstories/81%20swap.pdf Apparently a factory OEM gas pedal from a 94-02 CHEVY GMC 6.5L V8 DIESEL (PN 15984422) will bolt right in. You have to repin a few wires, but it's supposed to be pretty straight forward. The .pdf file has a complete discussion on the entire install, but here is a small snippet: "This is the installed Pedal Position Sensor AKA Drive by Wire pedal. I used one from a 1998 6.5 Diesel truck as it bolts right up and is a closer match than the later Silverado pedal. A couple of the wires do have to be moved as it is internally wired different. Basically, there are three different sensors in the pedal and the PCM compares all three of these to determine how much throttle opening the drivers is requiring. If these three sensors do not agree, a code will be set and the PCM takes a best guess at what the throttle opening should be. The gray wire was moved from location A to J, the Brown wire was moved from location E to A and the Yellow wire was moved from location J to E. I also had to add a slot in the connector plug so it would plug into the pedal." PLEASE NOTE I HAVEN'T TRIED THIS ON A TRUCK, I'M JUST PASSING THE INFORMATION. DO YOUR HOMEWORK BEFORE YOU PURCHASE ANY PARTS!!!! Good luck with your LS Swap!!!
05-18-2016, 11:10 PM | #18 | |
I'm a little intimidated swapping wires around. Is there a guide on how to move wires around on the connector? How do I get the wise out of the connector without damaging them? And then how do I reinstall them? I'm pretty much done with my swap, and it drives great,but the pedal is way out of position. Hate to go screwing with my harness if everything is working, but the diesel pedal sounds like a good idea.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
05-19-2016, 08:57 AM | #19 | |
05-19-2016, 12:31 PM | #20 |
Addicted to Rust
The Kicker is finding the pedal. 300 ish new. And used ones are problematic. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
05-19-2016, 01:00 PM | #21 | |
http://www.rockauto.com/en/moreinfo....1380181&jsn=10
05-19-2016, 01:22 PM | #22 | |||
If you're looking for a used one car-part.com and eBay are good places to look ($45-90+). Also, Dorman makes a replacement sensor (#699-207) for around $80-90 so if you get a bad one cheap enough it still might be cheaper than buying a new one... Quote:
https://www.youtube.com/watch?v=ebO4-EwMJDM Quote:
05-19-2016, 01:35 PM | #23 | |
Addicted to Rust
08-08-2017, 06:47 PM | #24 |
1965 Chevy C10, 2005 4.8L/4l60
I am curious if this bracket would also work on 2009 and up pedals? I have a 2014 going in a 64 c20. Could you share an up close picture please??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-08-2017, 06:49 PM | #25 |
Do you have a picture of your pedal?
