Old 02-16-2015, 02:49 PM   #1
bpmack16
rim ?
on a 72 c10 with a 4.5/6 deop what back spacing is recommended? all so what would push the rim out from the truck more a 4.75 BS , a 5.25 BS or 5.5 BS?
bpmack16 is offline   Reply With Quote
Old 02-16-2015, 07:03 PM   #2
Dhartley70
Re: rim ?
The more backspace the more the rim tucks under the truck. So 4.75" of backspace would put your wheels out more than 5.5" would.
Dhartley70 is offline   Reply With Quote
Old 02-17-2015, 04:29 PM   #3
bpmack16
Re: rim ?
Ok so now would a 72 c10 with 5x5 lug rear end be wider than the same year 6 lug rear end or are they the same?
Old 02-17-2015, 04:36 PM   #4
SCOTI
SCOTI's Avatar
Re: rim ?
72 5-lug rears are wider vs the pre-70 6-lug units by 1.5" (.750" ea side).
Backspacing will ultimately depend on wheel width as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-17-2015, 05:01 PM   #5
bpmack16
Re: rim ?
So I just measured my 72, 5 lug rear and it is dead on 64in. Could my drums be thicker than stock.
Old 02-17-2015, 05:20 PM   #6
SCOTI
SCOTI's Avatar
Re: rim ?
Possible.....
63-70 6-lug housings are about 62" wheel mounting surface to wheel mounting surface (the measurement I got when I measured my 68 housing w/5-lug Moser axles & new 71/72 drums).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
