Old 02-16-2015, 05:31 PM   #1
esahic
Angry What do I do with my hacked 72 cheyenne?
Ive been dealing with a problem with my 72 c10. I purchased the truck as a SWB that had a 90s bed on it. So after getting a 67-72 fleet side bed to replace the 90s bed I noticed that the truck was originally a LWB cut down to a SWB. It was really ****ty work. I think it was cut to short as well.
So what are my options?
I also have access to a 2002 gmc single cab truck! Could I swap the 72 cab and bed onto the 02 gmc truck and keep it titled as the 72 c10?
esahic is offline   Reply With Quote
Old 02-16-2015, 05:34 PM   #2
Tim Christian
Tim Christian's Avatar
Re: What do I do with my hacked 72 cheyenne?
I would just find me a good short bed frame and move everything over.
Tim Christian is offline   Reply With Quote
Old 02-16-2015, 05:36 PM   #3
68bowtie
68bowtie's Avatar
title goes with the cab, so you should be good to go with the 02 frame. or since you have the right bed the easiest/cheapest would be to find a donor 67-72 swb rolling chassis. or if you had a bare frame, swap all the suspension from the shortened frame.
Old 02-16-2015, 05:44 PM   #4
esahic
How hard would it be to swap the 72 cab, front end and bed onto the 2002 gmc? That way I have newer suspension and the LS motor. Has anyone done this? I tried searching the forum, but I couldn't find anything.
Old 02-16-2015, 06:39 PM   #5
65standard
65standard's Avatar
I would just repair the frame on the truck.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-16-2015, 06:53 PM   #6
1968aj
get frame welded properly then drive it like you stole it.
1968aj is offline   Reply With Quote
Old 02-16-2015, 06:54 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
X2 or sell it for another
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 02-16-2015, 07:09 PM   #8
Fitz
The factory assembly manual for your truck contains a dimensioned drawing of the longbed and shortbed frames. Get the book, measure out your frame. If you need to add a piece to get it to the correct length measuring the frame from reference point to reference point as shown in the drawing will show you where length needs to be added. Then you can get it repaired correctly. Fixing a hack job isn't that herd if you can weld.
Fitz is offline   Reply With Quote
Old 02-16-2015, 07:15 PM   #9
Greasey Harley
Greasey Harley's Avatar
I keep seeing people saying this, but it's not true in every state. If you have the titled cab on an untitled frame, there are multiple states that you can never register that vehicle in.
Some states will even impound the vehicle, pending further investigation!
It is always a good idea to document frame changes with the DMV.
Greasey Harley is offline   Reply With Quote
Old 02-16-2015, 07:22 PM   #10
esahic
Okay so most everyone is saying fix the frame or buy another 67-72 frame.
So swapping the body onto the 2002 gmc would be more work then what its worth?
I have never welded anything, but it is something I want to learn how to do!
Old 02-16-2015, 08:29 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yes... nothing will line up and there will be a lot of fabrication work. Way more than if you were to even weld your existing frame yourself.
A competent welding shop should be able to repair the frame for under 500 bucks. That's just a number I pulled out of my rear... so it will probably be lower.
Post up a pic if you can.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-16-2015, 09:20 PM   #12
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
What part of Texas are you in? maybe an experienced member would take a look and give a recomendation based on actual observation of the frame.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 02-16-2015, 09:43 PM   #13
bbcmudtruck
I literally laughed out loud when I read this haha. I found myself in the EXACT same position when I bought my swb. It had a 90s style step side bed that was fitted to a lwb leaf spring frame. I bought an original 67 bed for it and when I went to put it on the truck, I found out that the truck had been cut 3 inches too short... So what I ended up doing was buying a complete 68 short bed truck to swap frames. Its since turned into a complete frame up resto-mod. Dam you ocd!
bbcmudtruck is offline   Reply With Quote
Old 02-16-2015, 10:03 PM   #14
Mock1
Really need to see some pics of the hack to give you an idea of how bad the work is.
To you it my look like to rail cars were playin chicken at ,100 mph.
To me it may not look like much at all.
Swappin the old body on the new chassis would be more for a level 6 builder, you're at best probably a two. ( no offense)
If you have never welded before, your first welding job should NOT be a frame.
Post pics.
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 02-16-2015, 10:09 PM   #15
Trixxterr
In to see this truck...
Trixxterr is offline   Reply With Quote
Old 02-16-2015, 11:30 PM   #16
I'd find another good frame or fix if not too bad.
Old 02-17-2015, 12:56 PM   #17
esahic
I am located in Arlington TX. I have been on the look out for a another frame. I will post some pics of the frame when I get a chance.
I would Just sell the truck and move on, but this one is a cheyenne and has a lot of options that I think is worth fixing.
I also have a 69 c10 swb that I have been working on. Im new to all this so im trying to get some experience and learn as I go.
Old 02-17-2015, 12:58 PM   #18
esahic
This is my 69. I had to buy a bed or this one too, because it didn't come with one.
Old 02-17-2015, 01:00 PM   #19
esahic
This is the 72. You can see how the bed doesn't even sit right on the frame and the holes for the bolts are about 1-2" off.
Old 02-17-2015, 01:03 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
Nice short fleet beds seem to be harder to find than frames and it looks like you found two of them! Just keep looking for a frame, you'll find one. Bring a tape with you to make sure it's square. Find similar points (holes/rivets, etc) and cross measure, etc.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-17-2015, 01:10 PM   #21
esahic
Man it took me a while to find the beds but I got lucky. I found a rolling frame for $500 and I found another guy selling frame only, but he hasn't gotten back to me yet on price.
Old 02-17-2015, 01:11 PM   #22
leftybass209
leftybass209's Avatar
This isn't accurate for California either as I've spoken to the CHP and DMV extensively about this for my situation. All states have different requirements and everything isn't lumped into one generic category. The amount of documentation you have can greatly support you in certain situations.
leftybass209 is offline   Reply With Quote
Old 02-17-2015, 01:53 PM   #23
GASoline71
GASoline71's Avatar
So was a late model rear part of the frame spliced on to the existing '72 frame?
Need pics of where the frame is spliced/cut and welded.
Gary
Old 02-17-2015, 02:22 PM   #24
bbcmudtruck
When looking for a donor frame, pay special attention to the rear area around the coil springs. Right above where the coil springs mount to the frame. I didn't pay close enough attention when I went out and bought my donor truck and I had to spend major time and effort cutting the bad spots of the frame out and fitting/welding new pieces in.
Old 02-17-2015, 02:50 PM   #25
mcbassin
Still Learning
mcbassin's Avatar
Find another frame and put your stuff on it. They come up on craigslist occasionally.
mcbassin is offline   Reply With Quote
