Old 02-16-2015, 07:58 PM   #1
watsontyson
over heating
I have a 1960 Chevy 1/2 ton fleetside,short bed with a 235 in line 6 cylinder. new 3 cor aluminum radiator, new water pump, hoses, ect but it still over heats just a short drive time. which way should the stock fan go on?
watsontyson is offline   Reply With Quote
Old 02-16-2015, 08:13 PM   #2
PGSigns
PGSigns's Avatar
Re: over heating
It blows air onto the engine and pulls air through the radiator. Do you have a good temp gauge on the truck?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-16-2015, 08:49 PM   #3
watsontyson
Re: over heating
I just installed a new temp. gauge. it was showing about 220 - 230 degrees after just less than a mile. I've change thermostat and timing, although I might be too advanced
Old 02-16-2015, 09:09 PM   #4
Monte's62
Re: over heating
Heating up that quick makes me think your not getting the proper water flow. I don't think its an air issue.
Monte's62 is offline   Reply With Quote
Old 02-16-2015, 10:38 PM   #5
cv65
cv65's Avatar
Re: over heating
Hi heres my 2 cents for what its worth,did you have overheating problem before you changed all the parts rad,pump, hoses or was that done to solve overheating problem? could be as simple as air traped in system or as bad as cracked head or blown head gasket just need more info,Id try burping it,you can find out how online, or may search this site for old post on overheating
cv65 is offline   Reply With Quote
