Old 02-16-2015, 09:00 PM   #1
rs74
rs74's Avatar
Heater issue. Imagine that.
I have heat and it will run you out but it is still not working right. It mainly is coming out of the vents hot and the floor warm. I can't get the positions to change. I checked the white clip that holds the threaded rod for the blend door and it is good. I did find a broken vacuum line in the engine compartment and fixed that but the door still doesn't work even though I can hear the vacuum change at the control. I am wondering if the other door (not sure what it's called) could be broke. I know it has a plastic hinge on it. I haven't tore that far into it yet but I am not sure what else it could be. What controls that second door. I know when on high it does not sound like my K30 does when it is on high and it doesn't blow near as hard as the K30 does. I might try to look at it tomorrow. Any ideas?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
