Old 02-16-2015, 09:03 PM   #1
rs74
rs74's Avatar
What is the yellow wire for?
I did alot of work today on the diesel short bed and came across this. The yellow wire has been cut but not sure where it is supposed to go. Trying to get all the little things taken care of and wondering if I need to do something with this.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-17-2015, 10:10 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: What is the yellow wire for?
Looks like an accessory 12v + wire. Probably someone added it over the years to send power somewhere else.
Old 02-17-2015, 10:13 AM   #3
rs74
rs74's Avatar
Thanks. Trying to get all the small things figured out on this truck. I won't worry about the wire then. Just take it off. Now I have to see about why sometimes it wants to have a normal high idle on start up and other times it has a really low idle and sometimes dies. Then figure out why it smokes soo much on start up and warm up.
Roy
1987 R10 shortie
Old 02-17-2015, 10:42 AM   #4
68post
Sorry but I'm not familiar with what is OEM - but that is possibly part of the glow plug circuit either OEM or added on. !?
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 02-17-2015, 06:41 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
You probably have a cold idle solenoid on the injection pump. It is also used to bump the idle up when the heater controls are placed in Defrost or AC position to help with the load of the compressor.
If you have lots of white smoke on start up you more than likely have a/some failed glow plugs. If it's blue smoke you're burning oil.
Old 02-18-2015, 01:20 AM   #6
reporter000001
does it come from the junction block? or did some one drill a hole? my book says speed switch relay closed above 900rpm.
but this book isnt accuate for diesel...perfect for gas... i found this info in the straight6 section .......so no guarntees......
reporter000001 is offline   Reply With Quote
Old 02-18-2015, 09:47 AM   #7
Corts60
Just here to tinker
Corts60's Avatar
Not the same thing.
