Old 02-16-2015, 09:47 PM   #1
Rod Run
Rod Run's Avatar
Question Lower control arm alignment ?
I'm about to start re-assembly and have got to wondering....
How does everyone line up their LCAs before tightening the u-bolts?
How do you know if they are located correctly (not to far forward or back)? I repainted mine, so I have no old markings to go by.
Thanks in advance, for any help you all can give
I just realized that I probably should have asked this in the suspension section. Hopefully I can still get some good feedback in here
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-16-2015, 11:13 PM   #2
Wrenchbender Ret
Re: Lower control arm alignment ?
There is a hole in the shaft near the rear bushing. It lines up with a peg in the rear mounting were the shaft goes.
Wrenchbender Ret is offline   Reply With Quote
Old 02-17-2015, 11:14 AM   #3
Rod Run
Rod Run's Avatar
More of an indent than a hole, right?
Old 02-17-2015, 12:36 PM   #4
Possmguts
Possmguts's Avatar
Its the only hole or indent in the A-arm shaft...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 02-17-2015, 12:41 PM   #5
Rod Run
Rod Run's Avatar
Thanks guys!
Old 02-17-2015, 01:39 PM   #6
Rod Run
Rod Run's Avatar
Just to clear up any possible confusion, for anyone that might read this.... The indent is actually on the shaft, at the front of the control arm.
Probably didn't need to be said, but I know sometimes people get confused and I've seen people try to put control arms on backwards on other vehicles
I want to thank you guys again, because lining those up were a piece of cake
Old 02-17-2015, 05:03 PM   #7
Wrenchbender Ret
I'm glad you got it figured. I used to work on 30 series trucks & they have the locator at the rear mount.
Old 02-18-2015, 11:56 AM   #8
Rod Run
Rod Run's Avatar
Not a problem. I just got my new spindles in the mail yesterday, so I will be installing them today (I painted them last night)
