02-16-2015, 10:51 PM | #1 |
Need advice on I.D. Of another bracket
I have one more bracket that i need to identify and how it mounts, i usually leave everything bolted on or put it back on so i dont have problems of how it goes back, but i decided to let my grandson help and he took a few things off and i didnt tell him to label or etc. Anyway here is my last bracket , need help of where it goes and how it bolts on. Thanks for advice in the pass!
02-17-2015, 09:31 AM | #2 |
Re: Need advice on I.D. Of another bracket
Back side of the power steering pump ? bolted to the block?
02-17-2015, 09:34 AM | #3 |
That's what I was thinking, too. It's been a long time since I saw the bracket assembly all apart.
02-17-2015, 09:47 AM | #4 |
If it's not on the back side of the power steering pump, it may also be an alternator adjustment bracket
2005 Chevy Silverado 2500HD- DD 1970 Chevy C10 SWB 454 BBC- Work In Progress |
02-17-2015, 10:04 AM | #5 |
I also think power steering adjustment arm between the pump and the block.
"Life is too short to drive a boring vehicle". Later, Wayne |
02-17-2015, 07:47 PM | #6 |
Thanks.
02-18-2015, 11:49 AM | #7 |
I check alternator bracket, I have it but changed it to a Billet. I checked everyway I could still cannot get it to bolt up I still think it came off the steering box but it won't line up on the back, it does go on a LWP I see where the left bolts to water pump and top left bolts in AC bracket on the heads but when I bolt it there it seems to restrict the adj.does it have a spacer at the head bolt and on the bottom there is a slide slot to adj. can't seen to see how it bolts . I must be missing a part I may need to post a picture. Any suggestions
02-18-2015, 11:56 AM | #8 |
I can check mine tonight and let you know...
02-18-2015, 08:31 PM | #9 |
I am going to try to post some pictures , last time they did not post , may be because I'm new
02-18-2015, 08:37 PM | #10 |
I think I have loaded some pictures , if not I'll try again
02-18-2015, 08:55 PM | #11 |
Trying to load picture of steering box
02-18-2015, 08:59 PM | #12 |
Front side , you can see it mounts to the LWP and seems to bolt up to top bolt on the head , but may need a spacer , it seems to pull to close and steering box doesn't adj. but still need advice on bottom where you can see where to adj. the belt where it bolts up , I must be missing something .
