Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-17-2015, 01:06 PM   #1
swamp rat
swamp rat's Avatar
Air compressor explodes.
I saw this on Facebook this morning and thought i'd post it here, if you have an old air compressor this is something to think about.
https://www.youtube.com/watch?v=KVP_A7eGYxw
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-17-2015, 10:18 PM   #2
dkauffman05
dkauffman05's Avatar
Re: Air compressor explodes.
I think about this all the time . It's a scarry thought. I work on compessors for a living.
dkauffman05 is offline   Reply With Quote
Old 02-18-2015, 09:46 AM   #3
cg285
look at the compressor. it's a toy. not rusty either. probably chinese. in all my years i've never heard of compressor explosions in auto shops. pcv pipe - yes.
there used to be a guy who sold/serviced compressors in the orlando area. he used to make water separators from marbles in a large pvc pipe. don't know if there ever where failures but THAT sounds scary to me.
cg285 is offline   Reply With Quote
Old 03-01-2015, 12:39 PM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
I see it's a Craftsman
which doesn't mean the tank didn't come from china
I do see that it's rusted along the bottom where it came apart.
I don't think it should have blew up like that.
I think it would've/should've split open at the rusted area expunged all its air ...end of
compressor end of story!
Seeing the end caps blown completely off like that would lead me more in the direction of faulty tank construction and/or some one jacked up the regulator,but the tank should have handled that.
I'm rebuilding one similar to that...Forney Ind. 1975 or 76.
Peeking into the tank ,these is rust but not as bad as I thought considering it has a dead plug and not a drain (I will be changing that).
After seeing that one I will be taking ultra sonic depth meter readings on how much wall is left along the bottom.
Lucky for me we use them at my work.
Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 03-01-2015, 02:27 PM   #5
truckdude239
truckdude239's Avatar
its a cheap compressor my compressors at work one is 20 years old the other about 10 and they are inspected yearly for jus tthat reason by the state
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-01-2015, 03:33 PM   #6
xRAY76
ouch...hope the old man was ok
xRAY76 is offline   Reply With Quote
Old 03-02-2015, 12:03 AM   #7
bpatrol
wow I would have died from a heart attack much less the injuries. Looks like your father is one tough guy.
bpatrol
bpatrol is offline   Reply With Quote
Old 03-08-2015, 05:15 PM   #8
68c10airstream
68c10airstream's Avatar
I work in a power plant full of pressure vessels, receiver tanks, air storage tanks, etc. All of the tanks have welded on tags stating it's working pressure (WP) and rated temp, etc. This tag is part of a safely designed tank meeting design requirements put out from the AMERICAN SOCIETY OF MECHANICAL ENGINEERS (ALSO KNOWN ASME). No tag, Not safe in my eyes. Our power plant is 50 years old, i've drained 100's of gallons of water out of compressed tanks and never so mach as a pin hole
68c10airstream is offline   Reply With Quote
Old 03-30-2015, 05:49 PM   #9
chip46wis
WOW!!!! never heard of such a thing happening----hope he was ok!
chip46wis is offline   Reply With Quote
Old 03-30-2015, 06:44 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
I've seen the Home depot and Lowes compressors fracture at the compressor mount. They had a recall on then a few years back
dwcsr is offline   Reply With Quote
Old 04-14-2015, 12:36 AM   #11
In The Ten Ring
Pressure is what makes bombs work.
I hope the guy in this video is OK.....he looked like he had a limp.
In The Ten Ring is offline   Reply With Quote
Old 04-16-2015, 01:52 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This just makes me want to do this intentionally.....out to the farmlands we go.
Cmon, explosions are fun when you know they are going to happen.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-17-2015, 05:35 AM   #13
I just had the regulator rebuilt on my portable. It seems that should blow before the tank. Must have been a bad weld.
Old 04-17-2015, 01:47 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I usually keep some air brake antifreeze in my compressor since we still use it in winter. I suppose in winter its possible that the PRV could be frozen or rusted in place or something.
Old 04-22-2015, 12:48 PM   #15
Super_Dave
Super_Dave's Avatar
I've been thinking that an explosion blanket or enclosure might be in order for my shop. Blankets work great on transmissions, why not compressors?
On a commercial level, this company is nearby and I have been on contact with them.
http://totalshield.com/total-impact-...st-containment
https://www.youtube.com/watch?v=mk0-Fypr4Aw
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
