Old 02-17-2015, 03:24 PM   #1
Racker
Racker's Avatar
Body Line Question
Has anybody ever thought about making the body line on a '55 step side fender line up with the body line on the body? I understand that would raise the top of the bed also, maybe around the bottom of the back window area which I am find with that idea. Been playing around with the idea for the last couple of days. I have blocked up the fenders and stood back from it but only about 5' (run into shop wall, weather is to bad to push outside).
If some one could take this picture and photo shop it, I would be great full.
Life is not ment to show up at the grave in a well preserved body....but to show up in a well worn out body, sliding in sideways yelling, "WHAT A HELL OF A RIDE !!!!!"
Racker is offline   Reply With Quote
Old 02-17-2015, 03:27 PM   #2
Racker
Racker's Avatar
Re: Body Line Question
This is the actual truck I'm build this idea for:
Thank you again for any help/input from you guys.
Old 02-17-2015, 04:57 PM   #3
Kim57
Kim57's Avatar
It has been done.
There were pictures of one being done at a pro shop.
I can't remember who posted it as it has been a while.
I understand they sectioned the cab and front fenders to line up with the rear fenders.
I may be wrong about that though.
It did look real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-17-2015, 05:50 PM   #4
Racker
Racker's Avatar
Thanks Kim, guess I will do some more research and see if I can find it.
Old 02-18-2015, 09:21 PM   #5
G&R's57GMC
G&R's57GMC's Avatar
Attachment 1365317
Heck I've been thinking that since 1955 !
I've always wondered why GM didn't do that in the design dept.
I suppose if you had rusty door bottoms , steps and lower hinge pocket to repair. One could raise the bed to align the body line and trim and repair the lower part of the cab to match the step on the bed.
It would make the cab look a little less tall and may from a very low angle show the chassis. Something to ponder .
I just measured and were only talking about 4".
Now If the cab is good, raising the bed 4" and moving it back 1" to clear the back of the cab you would only have to add a 4" filler to the step to have it line up with the bottom of the cab.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 02-19-2015, 11:09 AM   #6
Racker
Racker's Avatar
I need to raise it so it will clear my duals when laid out on the ground.
Old 02-19-2015, 12:28 PM   #7
Keith Seymore
Keith Seymore's Avatar
I think it has to do with GM trying to reuse the existing stepside box structure across multiple design generations.
The mismatch extended all the way up through the 1987 versions (once you see it you cannot "un-see" it). Each subsequent re-design got a new cab and matching styled fleetside box but the stepside was essentially "carryover" box sides and gates with new fenders and steps tacked on (hence the mismatch). This saves GM tooling dollars but compromises the design process.
A friend sent me a write up on his pickup (a 40 Ford). I apologize for the Ford reference but it does show what can be accomplished when one has "an eye for the line". It also highlights the amount of hard work required to make it look effortless.
http://www.hotrod.com/how-to/paint-b...adster-pickup/
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-19-2015, 12:37 PM   #8
OrrieG
OrrieG's Avatar
Attachment 1365317
No photo shop but old school cut and paste. 4" top chop, 4" body, door and front fender channel. Body line line up and it all sits on the ground when aired out. To me it looks like a long bed, and the back fenders start looking big compared to the cab...
OrrieG is offline   Reply With Quote
Old 02-19-2015, 12:47 PM   #9
Keith Seymore
LOL!
"Old school cut and paste" = scotch tape and scissors.
I like yer style....
K
1979-1986
1986 - 2019
Old 02-19-2015, 01:15 PM   #10
1project2many
Yep. When I built my first truck as a teenager many years ago I raised the bed. It took three hockey pucks, I believe. Looked good but too much space between bed and frame. I didn't have skills or tools to extend the bed sides and lower the step back then. Prolly wouldn't see it on a lowered truck anyway but the style back then was more height.
1project2many is offline   Reply With Quote
Old 02-19-2015, 05:18 PM   #11
OrrieG
OrrieG's Avatar
Originally Posted by Keith Seymore View Post
LOL!
K
Trained as an architect when everything was still hand drawn pencil or ink on vellum. Took me less than 10 minutes, would have taken that long to find the computer program and install it on this machine!
Old 02-20-2015, 11:27 AM   #12
Keith Seymore
Lol. I did a mechanical drawing by hand a couple weeks ago. The preproduction shops called and the "line" was down because they were trying to build a manual trans vehicle with an automatic trans body. I whipped out my drafting kit and had a body patch designed and dimensioned within about an hour and got 'em going again.
My managers got a kick out it; I ended up with a $250 "One Time Recognition Award" for that one...
1979-1986
1986 - 2019
Old 02-20-2015, 12:42 PM   #13
OrrieG
OrrieG's Avatar
Yeah, I remember those Jr. high drafting classes where you had to do the plan, elevation and layout plan for complex shapes. Still use those skills today. One of my favorite books is my great grandfathers 1900's plasterers manual that shows how to layout complex arches, coves and other shapes just using common carpentry tools (wooden ruler, square, pencil, string and nails). A lot of my work in on historic buildings so I have lots of old building and product manuals to help deconstruct the design. I have extraordinary respect for the guys like my family members who showed up with a box of hand tools and $1000 worth of lumber, plaster and bricks and turned it into homes and businesses the first half of the 20th century. Those skills are not being taught or passed on, I was lucky growing up to learn mine. I heard that 60 percent of the blue collar tradesman currently working will retire in the next 15 years and there are very few people interested or the trade schools or unions to train their replacements, everyone wants to be a computer guru.
