02-17-2015, 04:45 PM | #1 |
Any pictures of Dropped Axle front ends?
Anyone using the original front suspension with a drop axle? can you please post a pic.
Anyone bagging these front ends? |
02-17-2015, 05:24 PM | #2 |
Re: Any pictures of Dropped Axle front ends?
3-4 inch dropped axle 3 inch lowered stock leafs done by a local leaf spring shop. New heavy duty tierod. And had sids do the steering arms. Still building it so havent driven it. But going to change over to camaro clip frame
02-17-2015, 10:33 PM | #3 |
4" drop with 2 leaves pulled.
02-18-2015, 12:01 AM | #4 |
Just got done skimming your build thread, awesome work and an inspiration to what I am now going to do. I've been looking at a s10 swap but really didn't want to go that route. I really wanted to keep the truck/chassis intact.
How is the ride (suspension wise)?, mine wasn't running when I got it. |
02-18-2015, 12:13 AM | #5 |
Here is my 55 1st series. Here it is on a 4" drop axle, 3" blocks and a few
Leaves removed. I do have pics of it with all of the leaves in if you are interested. [IMG][URL=http://s564.photobucket.com/user/stevealeve/media/IMG_20110819_185602.jpg.html] Also potentially thinking about selling the axle etc. so ... |
02-18-2015, 10:43 AM | #6 |
3" dropped axle and 3" dropped mono leafs up front. 6" dropped mono's in the rear
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-18-2015, 11:13 AM | #7 | |
I am going to replace the leaf springs with new and hope it improves. If not......maybe IFS at some point down the road. |
02-18-2015, 11:13 AM | #8 |
02-19-2015, 12:21 PM | #9 | |
02-21-2015, 09:45 AM | #10 |
02-21-2015, 10:18 AM | #11 |
Jeff, it is factory width and the tires do not rub at all. I did have issues with the steering linkage rubbing the leaves when I had the springs removed though.
02-21-2015, 06:35 PM | #12 |
FWIW, the PO of my truck removed leaves from the original, already tired springs, in an attempt to lower the truck... needless to say the truck bottomed out easily.
Mono springs are a good way to go when looking at suspension mods because the spring rate doesn't change like it does when removing leaves.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
