49 12v wiper kit location
I've just purchased a wiper kit but i have no idea how/where it fits. Has anyone got a picture of where their's is fitted? Thanks
under my dash looks like this-
yoshi's 49 project |
Re: 49 12v wiper kit location
It mounts in the bracket in the center of your picture, the one with slotted holes in it, with a support arm which mounts to the dash to fire wall support.
![]() Rob
My '47 C.O.E build |
Ok thanks, anyone else got any pics? Different angle? Thanks
You should have a brace from the firewall to the underside of the dash. You can see two screws/nuts in the previous picture right under the ignition switch mounting hole that secures this brace. This brace also holds the swing lever for opening the fresh air vent on the cowling. The lower(round) part of the wiper motor is mounted to this brace, with a piece of flat bar twisted 90*. You will have to improvise some, because it's not a direct fit. I had to used a spacer between the brace and mounting tab. Look closely and you can see the black tab with a short bolt used as a spacer. hope this helps. Wipers work good now.
I can get a photo of mine but will take a week now as away for work
1954 Chevy 3100 currently original. |
Yes that would be helpful, I'm going to a swap meet on Sunday maybe there'll be an AD there that I can have a look at
