Bench Seat Restoration
Hello everyone
So i have a 84 chevy bench seat but i want to restore it and put it into my 71. If i strip it down to bear metal can i just buy the foam and reupholster kit for a 71 and put it together. |
Re: Bench Seat Restoration
Anyone out there.
Old member
I'm not going to say 100% that you can are can't but I don't think the 71 seat foam will look right on the 84 seat frame you have.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks I'm glad i got someone to reply. Its harder than it looks on here.
#5 | |
Old member
![]() Quote:
If you want to try and put a 71 seat cover and foam on a different frame you would need to measure the frames on both seats and figure out if there are size differences, you need to compare the bottom spring structure and see if they are close to being the same ect.
It may help you to find out what year trucks had that same bench then do a search on the forum to see if it has been done before.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
