02-17-2015, 10:55 PM | #1 |
WTB 4x4 swap parts
what to buy parts to swap my long horn to 4x4 i have axle and springs i need shackles and hangers as ps box and arm thanks
02-18-2015, 09:03 PM | #2 |
Re: WTB 4x4 swap parts
02-18-2015, 09:37 PM | #3 |
thank i have a set here in town ill let you know if i still need them
02-19-2015, 12:25 AM | #4 |
I have a 4x4 P/S gear box with the pitman arm still installed. Have not used it myself but seems to have good seals with no leaks and the pitman arm responds well when the shaft is turned. One broken mount bolt but should be easy to drill and easy out. Also has the original high pressure and low pressure return line. Asking $60 plus shipping, let me know and I can post pics.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
02-19-2015, 12:28 AM | #5 |
plz do
02-19-2015, 02:39 AM | #6 |
I have every piece you will need for this swap.
Front spring/core support hangers are $40.00 each Front bump stops with brackets are $20.00 each. Front spring hangers (rear position, cast piece that shackles bolt to) $20.00 each Front spring shackles with bolts $12.50 each Engine cross member $75.00 Trans/transfer case cross member $65.00 Small transfer case mount (bolts to frame) $45.00 complete with rubber and bolts. Rear spring hanger (front position) $40.00 each Rear bump stops with brackets $20.00 each Rear spring hanger (rear position) is $45.00 each PS pump with brackets, hoses, gear box and steering arm $125.00. All prices plus shipping. Let me know. I have nice clean parts. Thank you, Thomas |
02-19-2015, 01:01 PM | #7 |
tyler, pics of the gear box with the 4x4 pitman arm attached. One broken mount bolt should be easy to drill and easy out. Seems all seals are good, am including the original press. and return hose merely for comparision for when buying new to match correctly. I would not use these as new hoses aren't that much $$. $60 plus shipping as mentioned. I am in Kansas about 30 miles south of Wichita, not sure where Ramona, Ok is but using UPS for shipping should not be too bad. Let me know if interested and I can figure a shipping quote. Thanks,
02-19-2015, 11:48 PM | #8 |
I have a 4x4 sway bar complete for $50 plus shipping
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
02-20-2015, 12:22 AM | #9 |
Ironhores I'll be up ur way Sunday I'll take the box what's the address and a good number
02-20-2015, 08:16 AM | #10 |
tyler, will be out of town Sunday. Sending you a PM.
02-23-2015, 05:24 PM | #11 |
tyler, still interested? Never heard from you via PM. ??
