![]() Join Date: Jun 2014
dash rattle please help
I know this is a long shot, but my truck has recently developed a rattle noise at certain speed while driving in the dash area. Its driving me crazy. My truck was almost completely rattle and squeak free when I got it....I think my damn exhaust is rattling this truck apart slowly. It's friggin loud (flowmaster 2 chambers dumped)
Anyways.....it sounds like loose pocket change rattling in the ashtray, I did in fact have loose change in the ashtray so I was hoping it was that but nope. I can't seem to see anything causing it. Anyone else have a rattle they've tracked down and fixed? Maybe it will give me some ideas of things to check. Any help or suggestions are appreciated. And I know these trucks are old and make noise.....I get it....I like it, but If I can fix an annoying rattle I will.... Thanks,
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
Re: dash rattle please help
I HATE dash rattles!
One thing I've done in the past is to have someone drive the truck and I sit in the passenger seat with an automotive stethoscope and look for the rattle. I've had good success with this method. I have found that in these trucks, sometimes the retractable end of the seatbelt will get cocked sideways and will rattle on the bottom part of the door. Kind of sounds like what you've described...also on my K20, the window crank mechanism has some wear (they are original) and they will rattle sometimes. Moving the crank a little usually shuts it up.... Hope you find it!
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I had dash rattles in the last 2 trucks I bought and it turned out to be change the previous owners left in the ashtray. The first one had 14.00 in change and the second one about 8.00 although this sounds like you probably have a different problem.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
not related to a dash rattle, but thought I'd post anyway's...I read somewhere that these trucks had a problem with a "Tuning Fork" hum kinda sound, from what I read, it was the hood hinge springs vibrating while under tension from the hood being down. Solution was to place some foam rubber tubing insulation inside the coils of the springs, hopefully, this will help someone with a similar issue.
I would try and look at the various braces/brackets behind the instrument cluster, or the radio/speaker bracket as well, hopefully, you will eliminate it by process of elimination....HTH, Ben ![]() |
,y glovebox rattled sometimes. could aslo be the dash pad. just look around when you hear it
I am a Referee of life.
I developed a rattle in mine, and about a mile down the road the speedo quit. You might try lubing it and the cable.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thanks guys for all your help!
I figured out what was causing the rattle....it was the chrome ring thing that's behind the right knob of the radio. It just spins round and round and I can't get it to stop or tighten. Not sure if it's supposed to be that way. I will take the knob off and see if I can secure it...if not I'll just fold a tiny piece of paper or something and cram it between the ring and where it meets the metal dash. This was causing the noise. Every time the noise started, I reached over and held the ring in my hand and it stops....let it go and the noise instantly came back! Whewww......that was driving me crazy!
Glad you found it!
![]() Maybe a very small piece of double sided tape would stop it from moving....
#9 | |
good idea!
