Old 02-18-2015, 03:58 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
oil pan removal
hi ya'll i have a light oil leak looks like from the rear main,now my ? is do i need to lift engine up a bit to remove pan it looks pretty close to the crossmember,my engine is a 6cyl 292 on my 63 c10,thx for your help.
1966FLEETSIDE is offline   Reply With Quote
Old 02-18-2015, 06:15 PM   #2
Wrenchbender Ret
Re: oil pan removal
Yes. You will have to raise it quite a bit. Remove the flywheel cover also,.
Wrenchbender Ret is offline   Reply With Quote
Old 02-18-2015, 08:25 PM   #3
T2vigil
T2vigil's Avatar
Re: oil pan removal
I did this last summer on my 250. Take the motor mount bolts out and jack the motor up far enough to put a 2X4 between the engine block and the top of the motor mount. After that as said earlier the flywheel cover.
T2vigil is offline   Reply With Quote
Old 02-18-2015, 10:37 PM   #4
Wrenchbender Ret
Re: oil pan removal
Also the shroud & watch that the fan blade does not get into the rad.
Old 02-19-2015, 11:22 AM   #5
vince1
Re: oil pan removal
I tried the stop leak and it may be already sealed after only 60 miles of driving. IMO that stuff works as advertised.
vince1 is offline   Reply With Quote
Old 02-19-2015, 07:46 PM   #6
1966FLEETSIDE
Re: oil pan removal
thx fellas sorry for the late reply.i dont have to release driveline do i??thx
Old 02-19-2015, 10:14 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Re: oil pan removal
Nope you won't have to take the drive shaft off. Take the two engine block mounts off and stuff a 2x4 under them...or something thicker if you can. It'll be a tad tedious to get the pan off cause of the lip in the pan. You'll see when you get the pan off, but with some patience it'll come off.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
