02-18-2015, 07:29 PM | #1 |
Gas Tank Conversion
What is the best cab-to-frame gas tank conversion kit?
Thanks, Mike |
02-18-2015, 07:36 PM | #2 |
Re: Gas Tank Conversion
I got mine from www.thecarantruckshop.com easy install .Don't forget you need to figure out your filler spout.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-18-2015, 08:01 PM | #3 |
Keepin an eye out
I bought a aluminum Boyd Welding tank, havent got it in yet but man it looks good sitting in my living room/
Just do a google search for them, they have a website.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
02-18-2015, 09:28 PM | #4 |
02-18-2015, 09:43 PM | #5 |
I also bought a Boyds tank and never looked back.
12-14-2017, 02:00 AM | #6 | |
Posted via Mobile Device |
12-14-2017, 08:32 AM | #7 |
Fuel tank upgrade, cab gas tank delete, moving gas tank from behind seat, Boyd fuel tank, Blazer gas tank replacement. That's a place to start anyway there are quite a few posts about it. Google deleted all my bookmarks so I am back to Square 1....I also went with Boyd fuel tank, made my own adapter for GM 93 Caprice fuel pump for my TBI conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
12-14-2017, 09:53 AM | #8 |
I used a stock Blazer (31 gal) in my C-30. Moved the filler spout to center after install.
12-14-2017, 10:03 AM | #9 |
12-15-2017, 01:12 PM | #10 |
search the posts for people using a 69 Camaro tank and flip down license plate for the fill tube.
I subscribed to that post I will see if I can find it
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
12-16-2017, 04:46 AM | #11 |
The blazer tanks have the spout towards the fender and some have the fuel door behind the marker light or in the bed. A 69 Camaro tank has the filler at the rear behind the license plate. The pics show the Boyd tank, all have advantages and disadvanteges
