cab bolts
just how important is having all 4 cab bolts in place. 1 area of the cab floor where the bolt passes through the support was damaged severely. but my other 3 are solid. I'm thinking of patching the area with scrape metal.
1968 Chevy C10 swb fleetside ![]() 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) ![]() |
Re: cab bolts
You'll probably expirence some weird cab vibration if you don't have all the bolts in. Oh and the vibration isn't what would bother me, I'd be worried about getting into a accident and the cab getting knocked off the frame. I'm sure you've debated that part too, just wanted to mention it.
Scott |
Re: cab bolts
Depends if you don't want the cab, and you with it, coming off in an accident I guess. GM was cheap. If three bolts would hold it, they would have used three.
With buckets the driver seat weighs a little more than the passenger seat and gets more bolts. If less would have held it, they wouldn't have added the extras. If you're looking for someone to say "it's OK", you'll be hard pressed to find anyone. Will it come apart on a left hand turn? Probably not. But it should be fixed.
Re: cab bolts
yeah guess i was hoping someone out there might have welded the cab in place, in lieu of solid cab bolts on hand. but now i can see how that would negate the use of the shock absorbing mounts/cushions.
Re: cab bolts
One of the first major fixes I did was polyurethane cab mounts. Weld in new metal if you can. If not, self tapping screws are a quick fix, just so it's solid on all 4 mounts.
Re: cab bolts
Not to high jack, but what are the bolt sizes needed to bolt it down? I have a cab that needs all four.
Re: cab bolts
I need to buy a new rear bolt also if someone wants to chime in with the size. And if I can buy 1 mount instead of all 4, couldn't find that online either
