I am planning on getting all my brake tube clips and w/h frame clips zinc coated but my plating company has a minimum charge so I need to get more parts done to make it worth while.
What is a list of parts you would get zinc plated off of these trucks? Mine is actually a Blazer but I thought I would get more views in this area. Thanks.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: What parts to get zinc plated on the truck?
Hatch latches and assoc bolts, carb air cleaner riser, could refurbish tower clamps. I did the stops and wedges for the hatch as well but not certain if it's the correct finish or not.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Carpe manana
The Older Generation
Door strikers, hatch latch parts, Master cyl lid (unless it's new), Gas tank filler neck/tube. If you haven't had the strikers off before be sure to mark around them with a fine felt tip marker so you can get them back in the same exact place. LockDoc
#5 | |
Carpe manana
Door strikers have a Parkerized (phosphate) black OEM coating
#7 | |
![]() LockDoc
I was in the same boat. Some of the other things I did, tail gate hinges and trunions, jack tool pouch springe and jack hold down hardware, spare tire carrier hardware.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
