Old 02-18-2015, 10:35 PM   #1
MAC71
MAC71's Avatar
Heat riser valve ?
Is the heat riser valve in the open or closed position?
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 02-18-2015, 10:59 PM   #2
seattle gmc
seattle gmc's Avatar
Re: Heat riser valve ?
looks like its in the closed position.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 02-19-2015, 01:58 AM   #3
MAC71
MAC71's Avatar
I thought it was closed. It moves freely but will not move to the other position even after a long highway drive. I just wired it to the other position and will see how it runs on the way to work in the morning.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 02-19-2015, 01:33 PM   #4
Userone
Userone's Avatar
I'm pretty sure the exhaust gas opens it when it flows shouldn't matter what temp its at
Userone is offline   Reply With Quote
Old 02-19-2015, 02:08 PM   #5
i82much
That is how mine works. When the truck is cold and you blip the throttle, it barely moves. When the truck is warmed up and you blip the throttle, it moves a lot more. I don't think it just opens up because it is hot. I think the bimetallic coil provides varying amounts of resistance against the exhaust depending on the temp, but unless you are giving it some throttle there isn't enough exhaust pressure to open it all the way even when it is fully warmed up.
i82much is offline   Reply With Quote
Old 02-19-2015, 04:44 PM   #6
seattle gmc
I just replaced mine. The only time it seems to open up is when i push lever down. Maybe it is moving when the throttle is aplied, i don't know?
