Old 02-18-2015, 11:40 PM   #1
gunrunner95
700r4 Trans with an LQ4
Okay so I have an 89 Silverado with a stock 350 and a 700r4. I'm waiting to do the popular LQ4 swap this summer perhaps so I'm doing research on it. My transmission was rebuilt back in November and has less than 1000miles on it so I'm hoping to use it, I know its possible to the old style of transmissions but I'm not clear what all is necessary/what kinds of issues may arise.
Any help is greatly appreciated Thank you.
1972 Chevy C-10 1/2 ton longbed project
1989 Chevy 1/2 ton shortbed
"If a man does his best, what else is there?"
"A pint of sweat saves a gallon of blood"-George Patton
gunrunner95 is offline   Reply With Quote
Old 02-19-2015, 12:24 PM   #2
rickpilgrim
Re: 700r4 Trans with an LQ4
LS motors have a longer crank on the flywheel end so that needs to be addressed with a bell housing spacer. Also, your LS has a different torque curve so use a mild stall speed lockup converter like GM does to get it in its power curve sooner. You may want to alter the shift points in the 700R4 also. Set your TV cable on the tight side and you should be good to go.
rickpilgrim is offline   Reply With Quote
Old 02-19-2015, 01:36 PM   #3
gunrunner95
Thank you Rick I appreciate it.
Old 02-19-2015, 07:21 PM   #4
Tom
driving is in my blood
Tom's Avatar
I'm a little confused, a mild convertor would be like the 350 uses, not high stall speed. LS's don't make torque until they rev, so they need a looser convertor to stall at a higher speed. To get any more mild then what a stock 5.7L uses you have to get a diesel convertor.
Old 02-19-2015, 09:07 PM   #5
rickpilgrim
What I mean by a mild stall converter is one with about 2200-2400rpm stall vs the 5.7's 1800-2000rpm stall. In laymans terms mild stall would equal looser.
A diesel converter is a 1000-1400 which would make milage improvement on a 5.7 but really act like a 4 cyl takeoff on an LS motor.
Hope that clears it up
