Old 02-19-2015, 12:28 AM   #1
775stepside
Oil pan removal
I looked online and can't find anything on 2wd. So I'm going to remove the oil pain on my 89 2wd and get it cleaned out since I installed new heads and just want to remove all the sludge on the pan. How difficult is it to remove the oil pan?
775stepside is offline   Reply With Quote
Old 02-19-2015, 08:50 AM   #2
BigBlocksRule
Re: Oil pan removal
Easy with the engine out.
You can remove the pan bolts, but the pan won't clear mains and rotating assembly with the engine in place, you'll have to lift it several inches at the least.
BigBlocksRule is offline   Reply With Quote
Old 02-19-2015, 02:31 PM   #3
775stepside
Re: Oil pan removal
Damnit ok thanks, of course it would be easy with the engine out but in this case it's not.
Old 02-19-2015, 02:35 PM   #4
sntrym95
sntrym95's Avatar
Re: Oil pan removal
I was able to get mine out on my 2wd 95 with a 350. It's tight but I didn't need to lift the motor. On the 4wd you have to lift the motor to get around the axle.
Mike
sntrym95 is offline   Reply With Quote
Old 02-19-2015, 02:58 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
Re: Oil pan removal
I assume we are working on a V8.
I have wiggled and jiggled them out of 2wds. On a few I've had to rise the engine slightly, less than 2 inches.
FYI, on 4wd models, it is a heck of a lot easier to drop the diff than raise the engine.
95 S_Trucker is offline   Reply With Quote
Old 02-19-2015, 03:42 PM   #6
BigBlocksRule
Re: Oil pan removal
I musta gave up too quick!
Old 02-19-2015, 08:56 PM   #7
775stepside
Re: Oil pan removal
Sweet that's nice to know, I didnt want to lift the engine, if I can wiggle it out I'll def try it. It is a 2wd 350
Old 02-20-2015, 02:02 AM   #8
Mr_Rich
Mr_Rich's Avatar
Re: Oil pan removal
I swapped out my 350 two years ago after trying to replace oil pan and timing cover gaskets on the engine I had in the truck at the time. I also replaced the left outer axle gasket on the front diff. Knowing what I know now I can say it would definitely be easier to drop the diff a little bit to pull the oil pan on a K-truck.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 02-20-2015, 12:12 PM   #9
rickpilgrim
Re: Oil pan removal
The last 93 C2500 we did oil pan replacement on we removed the motor mount pin bolts and used the floor jack and a 2x8 to raise the engine up 4" or so. We also removed the distributor cap and upper fan shroud to avoid damage. We placed 2-2x4 blocks under the mounts and removed the pan. Much easier to do this way then trying to fight getting the pan out IMHO
rickpilgrim is offline   Reply With Quote
Old 02-20-2015, 03:10 PM   #10
775stepside
Re: Oil pan removal
So at first did u lift the motor by the pan and then set the 2x4 under the motor mounts to hold it in place? Doesn't seem like you can pull it out without having to lift it
Old 02-20-2015, 03:25 PM   #11
rickpilgrim
Re: Oil pan removal
Perhaps not absolutely neccessary but made doing the job easier by being able to not only drop the pan down and out but also putting it back together without disturbing the new gaskets and end seals that were rtv'd to the engine block for a good seal.
Step 1- remove distributor cap and upper fan shroud
Step 2- remove motor mount bolts
Step 3- jack up engine with 2x8 on floor jack-use care
Lastly blocks under motor mounts to hold while removing pan.
I don't like any leaks and doing it this way all the gaskets and seals fit perfect with no drip/leak.
Old 02-20-2015, 06:06 PM   #12
775stepside
Re: Oil pan removal
Ok well I have the distributor out at the moment and fan shroud too, and exhaust manifold as I'm currently putting new heads on. Another question, what are the round gaskets that come with the oil pan gasket?
Old 02-20-2015, 06:15 PM   #13
rickpilgrim
Re: Oil pan removal
Most Fel Pro and Victor gasket sets include gaskets for the oil filter adapter in them, so that would be my guess without a pic. Also if your gasket set has 3 end seals in it carefully match up the old to get the right new one. If only 2 end seals don't worry about that.
Old 02-25-2015, 10:44 PM   #14
775stepside
Re: Oil pan removal
Well I finally removed it took me a couple hours, just removed the oil lines going to the ofh and removed the starter and it easily came out. Also the flywheel cover
Old 02-25-2015, 11:06 PM   #15
rickpilgrim
Re: Oil pan removal
Glad you got it out without without a problem.
Old 02-26-2015, 12:17 AM   #16
775stepside
Re: Oil pan removal
Yea it wasn't that bad at all just messy as hell.
Old 02-07-2018, 09:39 PM   #17
Harley03joe
Re: Oil pan removal
Has Anyone Used This New Oil Pan From E-Bay
NEW 86-02 SMALL BLOCK CHEVY FINNED OIL PAN,POLISHED,RIGHT SIDE DIPSTICK,262-350
eBay item number:401065811990
I Was Told It Will Work With Mr Gasket 5885 Not The Full Gasket
What Gives Hear I'M Confused
Harley03joe
P.S. I Have An
1987 Chevrolet R10 Silverado EFI Standard Cab Pickup 2-Door 5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated
1931 Ford Like New And For Sale
2004 Harley Davidson Heritage Classic
1987 Chevy R 10 Silverado
2007 Azera
2011 Cadillac CTS Premium
Harley03joe is offline   Reply With Quote
