Old 02-19-2015, 11:24 AM   #1
PancakeMix
PancakeMix's Avatar
67-72 frame, Dana 60 front axle... which variation?
'72 Chevy 3/4 ton frame, long bed
14 Bolt full float, cab and chassis rear end
8x6.5 budds
I'm trying to decide what front axle to run, and get it bought this winter. So come Spring, I'll have something fun to do. Have a nice rolling chassis.
The truck is going to be a street machine. POSSIBLE plow use. Lowered, or at least leveled. Nothing crazy.
I know my rear axle will bolt right in, aside from relocating a shock. I would like the same to happen on the front...
Does it matter what Dana 60 I buy for the front? There's so many different variations and things to consider though. Kingpin or balljoints. Different steering setups. Gearing. Old or new. GM, Dodge, Ford, IHC.
Chevy spring perches are all 32" wide, the rest are all bigger - so I'd have to find a Chevy one. And obviously will need one from a dually. Lug pattern should all be 8x6.5, until the newer axles.
From what I have searched on the forum and read online elsewhere, it looks like any Chevy Dana 60 front dually will bolt right up. Is that right?
1967 Chevy C50. Vortec 4200. 4L80E.
PancakeMix is offline   Reply With Quote
Old 02-19-2015, 12:35 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 67-72 frame, Dana 60 front axle... which variation?
Sub'd I'm going the same route gm 60... Be nice to know what I'm up against. I've got my plans made and ready for my 3100 but for my 72 I havnt even looked into it.
Tyler
57taskforce is offline   Reply With Quote
Old 02-19-2015, 06:15 PM   #3
CrewCab59
CrewCab59's Avatar
The GM 77-91 dana 60 only came with king pins. The 1st gen dodge will work as well with a few changes like wheel studs and shock mounts.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-19-2015, 11:42 PM   #4
I'm curious what is considered a 1st gen Dodge?
Old 02-20-2015, 12:58 AM   #5
CrewCab59
CrewCab59's Avatar
The 1st gen dodge 89-93 3/4 ton and 1 ton .Is just body style which had the 5.9 Cummins , the 4wd all had dana 60 and Dana 61 . The dana 61 had 3:08 gearing and 727 auto Trans.
1971 Chevy C/10
Old 02-20-2015, 01:09 AM   #6
SS Tim
SS Tim's Avatar
You know this! The 81-93, a facelift (barely) of the 72-80 trucks.
First generation comes from the fact this was the first bodystyle Dodge pickup to have the Cummins 5.9 diesel in 1989. Guess if you lump in the 78-79 Mitsubishi 4.0 diesel it becomes even more true
SS Tim is offline   Reply With Quote
Old 02-20-2015, 05:56 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
I believe the spring pads on a Dodge D60 are slightly wider.
If you're not doing heavy duty off roading with 37" or larger tires, keep the D44 and upgrade the guts...
Rich
1972 K5 Blazer CST Click HERE
Old 02-20-2015, 10:54 AM   #8
dell72
I used a mid 70's K 30 Dana 60 in my 72 K 20, bolted in with no mods. rear 14 bolt required different shock mounts
dell72 is offline   Reply With Quote
Old 02-20-2015, 01:54 PM   #9
CrewCab59
CrewCab59's Avatar
The gm dana 60 were 32" center to center , dodge are 32.5" . The dodge is about half the cost as a gm and that's why there a good buy. The 1/2" difference can be made up by off set spring bushings.
It just all depends what you can find and if you need a D60.
1971 Chevy C/10
Old 02-20-2015, 05:37 PM   #10
kwmech
Chevy/GMC spring centers are 31.5 and the Dodges are 32. Regardless there is a 1/2'' difference between the 2. Not uncommon to bolt in a dodge front end on a chevy 1/4'' per side is not that big a deal unless you have brand new springs, bushings and hangars that make everything really tight
Old 02-20-2015, 09:11 PM   #11
72MARIO
72MARIO's Avatar
Order. Off road design makes a offset spring bushing kit to fit a dodge axle.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-20-2015, 09:34 PM   #12
Orange Crate
Orange Crate's Avatar
Here is a good read:
http://www.pirate4x4.com/tech/billav...ont/index.html
I think this thread could be moved to the 4X4 section please.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
