Old 02-19-2015, 12:48 PM   #1
Longhorn 70
Longhorn 70's Avatar
Fuel fill through rear fender well?
I had a good friend when I was younger with a 1966 C20 (R.I.P). He had an extra fuel tank on the truck that was located on the driver's side between bed and frame rail under the bed. The fill was in the fender well in front of the tire so it couldn't be seen unless you knew where to look. He would put a cover (an opened tin can) over the the gas cap to keep dirt out of the lock. It worked great!! Does anyone make a kit or tank for this for our trucks?
As always, thanks in advance.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-19-2015, 02:13 PM   #2
Longhorn 70
Re: Fuel fill through rear fender well?
I was thinking about strapping a tank from a 73-87 in there....Think it'd work?
Old 02-19-2015, 02:17 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have a filler in my well. Would have to show you how I did it. All depends on what you are doing with the truck.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-19-2015, 02:43 PM   #4
Longhorn 70
Thanks Smitty...
I want the extra fuel capacity with a stock appearance. Which tank did you use and where do you have it mounted please?
Old 02-19-2015, 02:44 PM   #5
71meangreenc10
I have the suburban tank mounted under the frame at the rear. It is the poly type. If I did it again, I would have used metal.
Smitty
71 C30 Wrecker
Old 02-19-2015, 03:01 PM   #6
Longhorn 70
I found measurements for the 73-75 (may fit other years) side tank. 14x56x11 is what it lists as....I will measure when I get home and see if it'll fit in there.
Thanks for the info...
Old 02-19-2015, 04:30 PM   #7
SS Tim
SS Tim's Avatar
You are talking about the very common accessory/aftermarket saddle tanks added to most (it seems) C20-30s. Even the factory NL2 aux tank was pretty much the same. An often seen variation was the fender well fill (vs cut doors). Demco is one brand that comes to mind as using that style filler. The soup cans worked well at keeping grit off the filler but that area would pack with snow/ice on occasion.
Finding a tank or a pair used shouldn't be a problem. Either usable or as patterns. Tom probably has a set or two there in Mesa.
The other alternative is to install the NL2 tank installation on your truck as it would easily backfit. But the through the bed filler (Blazer style) is off-putting to some.
The 73 up tanks are designed to use a frame mounted cradle bracket and extend under the cab floor that is raised to allow the tank to nest. To me its not worth the effort given all the bolt ins around.
SS Tim is offline   Reply With Quote
