Old 02-19-2015, 02:00 PM   #1
Hunter92
Exclamation 92 Scottsdale TBI 350 Heavy throttle
Hey guys,
So my 92 has had a heavy throttle since I replaced the 350 with a rebuilt 350,
well to be more specific after I did the TBI gasket after the engine swap was completed had used the old one till then. At idle it's hard to hold the engine at anything lower then 1800 rpm when parked & and it's hard not to spin tires after a stop because the rpm's just go to 2000+ when I hit the throttle. Also occasionally when I get going from a stop the truck stumbles and sputters when I give it a little throttle
-92 K1500 TBI ECLB 5.7L 350 with
Heavy duty 5 leaf springpack
Airaid Cold Air Intake
Dynomax Exhaust Y-pipe Back no Cat dual rear side exit
Dakota Digital Blue digital dash with tach
Crystal composite Headlight assembly
Hunter92 is offline   Reply With Quote
Old 02-19-2015, 02:57 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 92 Scottsdale TBI 350 Heavy throttle
Unhook the throttle cable at the throttle body. Operate the throttle by hand. It should move nice and smooth.
Most likely your throttle cable is binding.
95 S_Trucker is offline   Reply With Quote
Old 02-19-2015, 03:10 PM   #3
ChevyTech
Welcome to the board!
http://67-72chevytrucks.com/vboard/s...Throttle+cable
The stumble is a seperate issue.
TPS
Fuel Pressure
EGR
Old 02-24-2015, 03:34 PM   #4
Hunter92
So apparently no one that ever looked at the engine auto techs included, noticed that the throttle and cruise cables were switched everyones feeling a little retarded for not noticing.
**** happens lol
