Old 02-19-2015, 04:46 PM   #1
RedRoad
RedRoad's Avatar
Dually rear with non dually rims
Would there be a problem running standard rims on a dually rear?
RedRoad is offline   Reply With Quote
Old 02-19-2015, 07:13 PM   #2
clapage6
Re: Dually rear with non dually rims
you just wouldn't be able to bolt 2 of them on there
clapage6 is offline   Reply With Quote
Old 02-19-2015, 09:06 PM   #3
RedRoad
RedRoad's Avatar
I figured that, but since the wheel centerline is not the same would it cause some kind of uneven load on the hub bearings or some kind of other accelerated wear?
Old 02-19-2015, 09:19 PM   #4
nonstop
The wheels would sit out further. As for bearings, it should still be fine with respect to the location between the wheel and hub. That distance has not changed.
nonstop is offline   Reply With Quote
Old 02-25-2015, 12:32 AM   #5
JustTom
I'm interested to hear anything you come up with.
I have a 84 cab/chassis with a stake bed.
I don't like the duals and want SRW, but I want stock diameter tires with 16in wheels.
I understand the cab/chassis rear end is narrower than the dually pick up rear end.
That should put the single tires in some.
I have another 84 C30, 2wd, SRW I can swap with.
I'll mess around with it in a couple months, when it's not zero degrees.
Tom
JustTom is offline   Reply With Quote
Old 02-25-2015, 12:48 AM   #6
rs74
rs74's Avatar
I think I have a pic of my truck from when the previous owner did this.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-25-2015, 02:07 AM   #7
68post
Tom
C & C dually axle is the same width as a SRW axle, and I could use that C & C axle if you want to part with it !?
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 02-25-2015, 08:23 AM   #8
andrewmp6
The cab and chassis is more narrow then a srw axle,People had tried using them and had to tube the bed inter fenders to run the drw.
andrewmp6 is offline   Reply With Quote
Old 02-25-2015, 11:06 AM   #9
68post
Hubs are the only difference and I have a flatbed.
63'' vs. 67" wms to wms
Tim K.
Old 02-26-2015, 08:15 AM   #10
BigBlocksRule
There's a small ledge on SRW hubs that prevent a dually rim from being mounted on it, so the center hole is a tiny bit larger on a SRW hub and wheel. Wheels should fit, make sure to use cone-shaped lugs that will center the wheel on studs.
BigBlocksRule is offline   Reply With Quote
Old 02-27-2015, 10:38 PM   #11
JustTom
Sorry, not looking to part with it.
Here's the truck.
The flat bed is 8x8.
It is a real pain when plowing snow, which is 90% of what this truck does.
I want to go SRW and narrow the flat bed to the width of the cab.
And, keep 16" wheels.
Old 02-27-2015, 10:45 PM   #12
JustTom
I never saw this truck in person, it was on CL for a while in N Michigan.
The owner didn't build it, but insisted it was a" factory dually".
I'm pretty sure it was a Cab and Chassis axle on a SRW truck.
I happen to think it looks OK.
Old 02-28-2015, 01:51 AM   #13
68post
I think so too ! Otherwise the bed wouldn't fit so good.
Tim K.
Old 02-28-2015, 07:44 PM   #14
dragn91
dragn91's Avatar
I wonder what a cab and chassis rear would look like under my crew cab stepside.
dragn91 is offline   Reply With Quote
Old 02-28-2015, 07:55 PM   #15
BigBlocksRule
You'd have to do some little tubs. Spring perches aren't in the same place as conventional cab-and-bed configuration, they're based on the old 34" wide frame rails, so you'd need to move them. Not a big deal.
There's a definite difference in the overall axle with a C&C. The SRW and DRW are based on the same axle tube setup, hubs are the only difference. The C&C is narrower overall. I have a dually C&C, could swap with SRW hubs and end up really narrow.
