Old 02-19-2015, 05:26 PM   #1
jh68c10
front suspension
I am putting 74 front suspension (crossmember and all) my 68 frame. Can anyone tell me what holes need to be drilled to make this work? And also I have none of the bolts. Can anyone tell me the sizes and lengths that I will need? Thanks
jh68c10 is offline   Reply With Quote
Old 02-19-2015, 07:35 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: front suspension
Don't know on the sizes but once you pull the old one off, you can match them. The holes that need to be "drilled" are there but don't line up enough to get a bolt thru. You'll have to drill thru what's there to get a bolt in. IIRC there's just one on each side that needs this. Make sure to use grade 8 bolts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-19-2015, 08:09 PM   #3
john
member #16
john's Avatar
LockDoc posted some pics, scroll down to post#14.
http://67-72chevytrucks.com/vboard/s...d.php?t=272538
john is offline   Reply With Quote
