Old 02-19-2015, 09:45 PM   #1
xxblade31
xxblade31's Avatar
70 C10 cant get gauge cluster out!
This my first post. I have bought a 1970 c10 shortie. Working on the interior. final things gauges can't seem to get old cluster out. OP put in new steering column. I think I have to drop it out of the way ? Or is there some trick I dont know? My new gauges are New Vintage USA out of Detriot.
Other mods in mind
4 wheel wilwood disc's
Doors need attention. thats a job in itself.
Gotta lots of loose ends first though.
Gauge pic below
Thanks in Advance.
xxblade31 is offline   Reply With Quote
Old 02-19-2015, 09:48 PM   #2
sduckworth13
sduckworth13's Avatar
Re: 70 C10 cant get gauge cluster out!
Here you go. Just click the link.
http://67-72chevytrucks.com/vboard/s...32#post1332032
Scott
sduckworth13 is offline   Reply With Quote
Old 02-19-2015, 09:59 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Here is the order of events you need to follow to remove your cluster properly.
First, disconnect the battery and pull the head light switch knob out all the way. Reach up under the dash and there is a small spring loaded button on top of the head light switch you need to depress that and pull the knob out at the same time.
Using a small flat blade (pocket screw driver) loosen the set screw and remove the wiper knob.
Remove the two chrome bezels for the head light switch and wiper switch.
Reach under the dash and remove the speedometer cable from the cluster. You may need some pliers but most of the time, the cable is hand tight.
Unplug the harness connector which is located right near the fuel gauge.
Using a 5/16 line wrench or very good quality wrench, remove the oil pressure line from the oil pressure gauge.
Remove the metal plate under the steering column and remove the strap that holds the column up. There is a debate on whether you actually need to drop the column but I would to be safe. Once the cluster is loose and you realize you do need to drop the column, it makes it more difficult than just spending the extra 5 minutes to drop it.
Once the column is down, remove the 6 screws that hold the cluster to the dash and pull the cluster out.
There you have it.
Hope this helps. Ask questions if you need further help.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-19-2015, 10:01 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by sduckworth13 View Post
Great link there Scott. It has photos to explain some of the instructions I gave. I think he is covered
Take care,
Tom
Old 02-19-2015, 10:01 PM   #5
xxblade31
xxblade31's Avatar
Thanks sduckworth Ill drop the column in the am.
Name:  gauges resize.jpg
Old 02-19-2015, 10:03 PM   #6
sduckworth13
That's a sharp looking cluster, what brand is that?
Scott
Old 02-19-2015, 10:18 PM   #7
xxblade31
xxblade31's Avatar
New Vintage USA 3D led lighting they look even better lit up. Hope I can handle install. I will just take my time.
Old 02-19-2015, 10:20 PM   #8
xxblade31
xxblade31's Avatar
My old gauges were dead. no temp gauge or fuel gauge. found thes on summit no tax or shipping.
Thank you TBONE
Old 02-19-2015, 10:45 PM   #9
sduckworth13
Thanks, it looks pretty nice. Good luck with your install. Oh, your truck looks great too.
Scott
