What Hump?
Six lug bolt pattern question
Are the 6 bolts for pre 72 1/2 tons 2wd and 6 bolt for 4x4's the same size as the newer chevy products, ie. 2002 1/2 ton extended cab?
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
97' Tahoe 2dr/2wd
as far as i know the answer is yes, although the newer chevy truck stuff has a different offset than the old ones, and some of the inner circles are different (the part around the hub), the newer ones are smaller than the old ones.
hope that helps |
huh?
![]() Join Date: May 2000
Yes, the bolt patterns are the same, 70-down had the 6 on 5.5 bolt pattern, 71-72 had disc brakes and a 5 on 5 pattern. Tommie is correct as well on the newer style wheels.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
