Old 02-20-2015, 09:36 AM   #1
Hart_Rod
Hart_Rod's Avatar
1986 Custom Deluxe computer?? Smog equipment???
I just bought a one owner rust free 86 SWB with 93K (305/700R4). Its a very clean truck that I don't plan on doing much to other than fixing a few small things:
heater core is leaking, replaced the temp sender, the seat needs recovered on the drivers side, I picked up a tilt for it, , had dual 50 series flowmasters exhaust put on it, I may drop it a little later on.....
One thing I have noticed about it is that it has a lot of smog stuff on it and it appears that it has a computer behind the glove box. Is the carb computer controlled? Is there a way to tune the computer? Can the smog stuff be eliminated? Should I just leave it alone and drive it? Thanks for the input.
Hart_Rod is offline   Reply With Quote
Old 02-21-2015, 09:27 AM   #2
86c20
86c20's Avatar
Re: 1986 Custom Deluxe computer?? Smog equipment???
its not a ecm for the carb its for the dizzy. trust me when i say this. replace the dizzy and leve that unhooked. you will never find one that works when that one dies and if you do. big money. form what i was told it has to do with adj the timing for smog crap.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 02-21-2015, 10:29 AM   #3
Slammed84
Slammed84's Avatar
Nice truck! Famous last words " I don't plan on doing much to it"
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 02-21-2015, 01:22 PM   #4
Liberty
Liberty's Avatar
I actually have that same exact computer unhooked in my 82 C10.
The truck originally had a 305 but the PO swapped it out for a 350.
If you ever need a spare ESC, I'll let you have it.
That being said, I have no idea if mine actually works.
Liberty is offline   Reply With Quote
Old 02-21-2015, 01:47 PM   #5
1974ChevyC30
1974ChevyC30's Avatar
As said above, the dizzy is computer controlled. The ICM changed from a 4 pin design to a 5-7 pin design. With the 5 pin design, it included a knock sensor but still have mechanical controls. With the 7 pin design the mechanical controls were done away with and became completely computer controlled. Someone correct me if I'm wrong.
1974 Chevy C30 Cheyenne Super Camper Special w/ Built 454/SM465(Daily Driver)
2008 Chevy Silverado 4.8L/4L60-E(Totaled)
"Government is not the solution to our problem, government is the problem."-Ronald Reagan
1974ChevyC30 is offline   Reply With Quote
Old 02-21-2015, 02:21 PM   #6
1970pelle
1970pelle's Avatar
I currently have a 86 C20 5.7L with a 4bbl. And had a 86 C10 with the same power train. I removed everything in about 2 hours. There was no cutting, ripping, tearing stuff. I didn't have to butcher anything up. Everything unbolts or unclips. The wiring harness is separate from the trucks main harness.
I called it the emissions harness, it comes in to the engine compartment just above the passenger side valve cover. I'm describing this with my knees touching the front bumper. I started out by unplugging everything that is connected to this harness. Then I removed the component or senor if possible.
I also removed the A.I.R pump and all its plumbing and rubber hoses. Plugged the exhaust manifolds for now, to be updated later on. I removed the ECM from behind the right mid center dash. And removed the harness as well. I took the big groment off the harness so I could reuse it. I passed my new gauges lines through that hole left there from the harness. I made the hole smaller by inserting a piece of 3/8 hose in the hole first. Then when all lines where finished being run, sealed everything with a sealer(black)
For the Distributor I bought a brand new one from Summit and dropped it right in. But if your truck has a distributor with a vacuum advance you can use the one already there. There is a post some where that tells which wires need tied together.
Piece of cake and it opens up the engine compartment, so you can see what your doing.
Ken
1970pelle is offline   Reply With Quote
Old 02-22-2015, 11:43 AM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks!
. I have plenty of other projects, I bought this truck for Home Depot runs, .
Thanks for the off!
Thanks!
Ken
Good write up Ken. How does it run after you did all of that?
Old 02-23-2015, 10:26 AM   #8
1970pelle
1970pelle's Avatar
My current truck run pretty good. It took a little playing with the feedback carb to get a base idle. One issue I'm fighting is my engine is very tired, due for a rebuild or replacement.
My last 86 C10 feedback carb had been running so lean it had backfired once in it's past and cracked the carb base. I chased a low vacuum reading at idle till I change out the intake manifold and carb. Then I found the bad Carb.
But I'm planning on dumping this carb and intake when I repower the truck soon. I would suggest getting rid of the feedback carb to one you can adjust better for your new set up.(exhaust,ignition)
Ken
Old 02-23-2015, 10:54 AM   #9
Hart_Rod
Hart_Rod's Avatar
Ken
How do you adjust the idle? I think my choke is staying partially closed causing it to idle to high.
Old 02-23-2015, 11:35 AM   #10
1970pelle
1970pelle's Avatar
Treat the carb like any Q-jet. Is the electric choke thermostat getting 12 volts when the key is on ? There is a fuse for that under the dash. And do you have vacuum to the choke pull off ? Take a look because they ran the vacuum to the pull of through a delay valve and all the way around front of the carb. I went from the manfold port in back of the carb. That sticks up from the intake.I can take a pic here .
Ken
Old 02-23-2015, 11:42 AM   #11
Hart_Rod
Hart_Rod's Avatar
Ken
A picture would be great, thanks!
Old 02-23-2015, 11:52 AM   #12
1970pelle
1970pelle's Avatar
Here you. Now I have to say first, I haven't done anything but the bare basic's to get this truck running. By far it isn't done or even close to be even started on. Its a drive to soccer & track practice. To watch my boys. I have two bike build going, then truck build time.
Anyway back to trucks. Its easy to see what I plugged and what I used. Please ask any questions and I'll try to my best to help.
Ken
Old 02-23-2015, 12:21 PM   #13
Hart_Rod
Hart_Rod's Avatar
Will do, thanks!
Old 02-23-2015, 12:27 PM   #14
MalibuSSwagon
Well this is odd. When I got my 86 C10, it still had the distributor and little computer, but someone had deleted the EGR, EVAP system, and maybe AIR. It had manifolds with no air fittings. But here's the thing, it had a harness going into the cab with just wiring for the distributor and knock sensor. No wires had been pruned or removed from this harness. Also distributor had a vacuum advance. Very weird. I removed all this stuff when I converted to TPI but kept the ECU distributor and harness.
MalibuSSwagon is offline   Reply With Quote
Old 02-23-2015, 01:16 PM   #15
1970pelle
1970pelle's Avatar
Not really. Remember my truck is a C20 which changes its CARB requirements if that's what you call it. Because of vehicle weight. My 86 C10 I had before was much like Hart Rod's truck. And I used the OEM Dist after a update till the day I sold it. I swap out the Vacuum advance to a adjustable one, new module, spring and weight kit. Saved me a few bucks.
For sure I dumped the feedback Q-jet as soon as I could. Either go with an old non feedback Q-jet or a new aftermarket carb or fuel injection.
I know some will moan over this, but I hate Q-jets. With my Mopar back ground
I'm a AFB guy all day long. When Dodge used the Q-jets on there trucks and ramchargers, motorhomes in the 80's. I had my fill of sorting them out. Give me a Thermoboog or a AFB and I'm in heaven. Sorry I saw a Duck.
ken
Old 02-23-2015, 03:01 PM   #16
jeremybadeker
Does anybody happen to have a 2 pin solenoid for the 86 feedback carb, or know where to get one?
jeremybadeker is offline   Reply With Quote
Old 02-23-2015, 06:25 PM   #17
1970pelle
1970pelle's Avatar
I'm looking to see if I still have any take off carbs. Will let you know asap.
Ken
Old 02-23-2015, 09:35 PM   #18
jeremybadeker
Ken
I got lucky and found one local. Thanks though!
Old 02-27-2015, 12:54 PM   #19
Hart_Rod
Hart_Rod's Avatar
Gonna have to mess with the carb this weekend. I had dual exhaust with an H pipe put on last weekend. Now if you are sitting in gear and REV it up, when you let off the gas it backfires. Any suggestions to what might be the problem? I've gotten spoiled by the EFI stuff...... . I'm pretty sure it is running to rich, as I can smell gas from the exhaust. Thanks for the help.
Old 03-04-2015, 11:17 AM   #20
Hart_Rod
Hart_Rod's Avatar
Bump
Old 03-04-2015, 02:59 PM   #21
donut
donut's Avatar
It could be running rich, lack of timing, stretched timing chain throwing everything wonky...
Old '86, 1/2 to I had years ago I had swapped the distributor and carb to an older model and took the ecm out of the equation. (years ago, as in pre-internet.)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
