Old 08-25-2003, 05:41 PM   #1
Russell
Professional Grade
Russell's Avatar
4 x 10 to 6 x 9 conversion brackets
Anyone have any suggestions on where to look for some? wanna replace the 4 x 10s with a pair of good 6 x 9s, on top of the pair of 4 x 6 and 6 x 9s that I already have installed...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-25-2003, 07:42 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If you are trying to mount 6X9 speakers in your cab corners, and you already have 4X10 speakers in factory mounts, you can reuse them. A friend of mine drilled new holes in the factory 4X10 brackets to allow him to bolt 6X9 speakers to it. Then he switched the bracket left to right and right to left. He had to drill new mounting holes, but it repositioned the speakers so that the magnets cleared the cab. He has a large set of Pioneer 6X9 speakers mounted in the cab corners that way.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
