Old 02-20-2015, 07:57 PM   #1
dtkarst
Having some steering issues on my K20
Ive been tinkering with my K20 since I got it, trying to get bugs worked out figure out why the cut the tape to all the wires from the fuse block etc etc. I noticed that when I drive it turns all the way left, but only maybe one turn tp the right. The previous owner converted it to power steering, and not the CaptainFab way lol. But this is what I found, looks llike a tie rod i think is hitting on the leaf springs when i turn right. Im wondering if it isnt a pitman arm issue, or what. Any help is appreciated, just not sure whats going on or what t do. thanks
dtkarst is offline   Reply With Quote
Old 02-20-2015, 07:58 PM   #2
dtkarst
Re: Having some steering issues on my K20
Ill try to get better pictures, didnt have it inside
Old 02-20-2015, 08:42 PM   #3
padresag
I take it that the frt end is the org knuckle joint frt end. you will have to shorten the steering arm that comes off the king pin area
ron
padresag is offline   Reply With Quote
Old 02-20-2015, 08:55 PM   #4
padresag
this has all been posted before under 61k10
ron
Old 02-21-2015, 01:10 AM   #5
Captainfab
60-66 Nut
As Ron said, the steering arm needs to be shortened.....and by a qualified welder I may add. That is not something that you want to fail.
Old 02-21-2015, 01:26 AM   #6
padresag
that one was on there when I got it. it worked for 20 years and there was also the extra weight of the detroit on that frt end
ron
Old 02-21-2015, 01:34 AM   #7
dtkarst
I looked at 61K10 build and saw he cut it 1-3/4 inches, that should be enough right? And I'll probably be getting that adapter plate since the last owner didn't do the best job and had too much fun with a welder
Old 02-21-2015, 01:55 AM   #8
padresag
that measurement that I show there worked real well on mine. you want it so that the travel of the pitman arm matches the travel of the steering arm and shortening the steering arm gives you that
ron
Old 02-21-2015, 01:35 PM   #9
61K10
61K10's Avatar
as ron said, as he did this mod way before me (thanks for the info ron) and ron i did plate my steering arm like yours top and bottom.
dt--looks like the clamp is hitting the spring perch, rotate it some. this should get you equal steering from side to side, just won't go all the way to the stops.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-22-2015, 11:30 AM   #10
RANDY COX
RANDY COX's Avatar
How about some pixs of your K20..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-22-2015, 02:53 PM   #11
dtkarst
Here's one that I snapped the other night, leans to one side since the PO put an old car tire on the front. I'll have more once it warms up here this week
Old 02-22-2015, 04:28 PM   #12
RANDY COX
RANDY COX's Avatar
KOOL yea it's been cold here too in VA...
1964 BBC 402 4x4
Old 02-22-2015, 04:51 PM   #13
joedoh
joedoh's Avatar
yeah 55 yesterday and snow today. gotta love kansas
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
