Old 02-21-2015, 07:25 PM   #1
jb3t
Custom Autosound Speaker Installation... Little help?
I am installing a custom autosound dual speaker in my 78 C10. Anyone know if the speaker gets installed from the top or the bottom. Top fits snug and holes line up perfectly. However, the speaker is raised a tad. If I install from below, it's flush with dash, holes line up, but there will be a little gap between the screw hole (speaker) and dash hole.
jb3t is offline   Reply With Quote
Old 02-22-2015, 02:51 AM   #2
jb3t
Re: Custom Autosound Speaker Installation... Little help?
Clarification.... I am talking about the single speaker in the middle of the dash. I bought a replacement from LMC, the Custom Autosound Dual. I took the dash off, cleaned up 35 years of gunk, and am now ready to install the speaker.
Here's the Question.... Does anyone know if the speaker drops in from above the dash or if you have to install from below the dash? Above = feels like natural fit but speaker protrudes a tad. From under, speaker does not protrude but the mounting bracket is not flush with the under dash
Old 01-13-2022, 02:16 PM   #3
silvertonguedevil
silvertonguedevil's Avatar
I came here to get an answer to this too. Anybody have any help they can offer?
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 01-13-2022, 03:06 PM   #4
rodstored-72
chevy truck fan
rodstored-72's Avatar
you might try looking/searching in the elctrical "truck audio" section too. it doesn't get as many views, but I bet you might find your answer if you do a "forum search"....good luck
rodstored-72 is offline   Reply With Quote
Old 01-13-2022, 03:50 PM   #5
69Tom
Crap. I just did this and I can't remember, 100%. I think it was from the bottom and I had to look it up when I did it, so pretty sure it's correct.
69Tom is offline   Reply With Quote
Old 01-13-2022, 06:53 PM   #6
K25alive
I replaced my center dash speaker last summer when I replaced the dash pad in my 1979 K25. I'm pretty sure the speaker sat on the dash and I screwed it in.
K25alive is offline   Reply With Quote
Old 01-13-2022, 07:25 PM   #7
Dead Parrot
Follow this thread to the bottom. https://67-72chevytrucks.com/vboard/...d.php?t=829234
May not apply to your particular speaker.
Dead Parrot is offline   Reply With Quote
Old 01-13-2022, 07:45 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Every unit I’ve seen sits on top
Old 01-13-2022, 09:01 PM   #9
TKCR
TKCR's Avatar
From the bottom, that’s how I did mine.
Old 01-15-2022, 08:36 AM   #10
Android04
Android04's Avatar
From the bottom is how I did mine as well.
Android04 is offline   Reply With Quote
Old 01-17-2022, 10:42 AM   #11
Shugalou
Shugalou's Avatar
Yup I did mine from the bottom. If you haven't bought parts yet you can buy a plastic adapter to fit two 3.5 speakers in there to get more a stereo sound. That's what I did and the adapter was mounted from the bottom
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 01-17-2022, 11:31 AM   #12
Bob Q
My original sat on top and I mounted the replacement on top as well.
Bob Q.
'83 K2500 6.2L
Bob Q is offline   Reply With Quote
Old 01-21-2022, 03:01 AM   #13
Pontiac1976
Pontiac1976's Avatar
When it the same a style sizing as factory there on top, when styling is thicker and bigger you may need to mount under or a drop bracket( made up custom made). So when it come to the set up what make to best fit for finish that you like or make the cab as factory looking as you can flow that style. So it comes down to what you want uses, and how you use part get the look you want done.
Some time adding foam cut out rings to any speaker will boot the sound throw the panel/open facing it to.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
