Old 02-21-2015, 09:26 PM   #1
jvs99560
jvs99560's Avatar
3/4 ton rear coils on 1972 c10?
I have a 72 c10 and plan on pulling a travel trailer as well as the occasional trailer load of firewood. Will i be able to remove my 1/2 ton coils and put in these AC DELCO # 45H2012 C20 coils? I'm wiling to replace a few parts if needed. Im not too concerned with ride quality which seems to be a downside with the heavier spring.
jvs99560 is offline   Reply With Quote
Old 02-21-2015, 09:53 PM   #2
65standard
65standard's Avatar
Re: 3/4 ton rear coils on 1972 c10?
Yes, they will bolt right in. Same with the front too.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-21-2015, 09:57 PM   #3
jvs99560
jvs99560's Avatar
Thanks! Ill probably order them then. And thats great to know on the fronts. I wonder if there would be any benefit to running the heavier spring on the front? The truck has a small block so not too heavy.
Old 02-21-2015, 11:18 PM   #4
Acorn
Stock c20 springs are the same load rate as heavy duty c10 springs. I can't find ithe links right now but if you search around here there are a few threads where people list different springs you can use.
Also if you don't want a stiff ride, you may coincided using helper springs
http://67-72chevytrucks.com/vboard/s...d.php?t=555869
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 02-21-2015, 11:22 PM   #5
jvs99560
jvs99560's Avatar
Thank you for the info. I will ask my mechanic what he thinks will be best for me. Hes worked on the truck since new haha.
Old 02-21-2015, 11:35 PM   #6
I put new 3/4t coils with Air Lift helper springs (bags inside coils) and that worked out really well. Used the truck as if it was a 3/4t for daily work
Old 02-21-2015, 11:37 PM   #7
jvs99560
jvs99560's Avatar
Was it expensive or require special fabrication to get that setup?
