Old 08-25-2003, 08:10 PM   #1
OneMpg
AC help! =)
I finally got some free time today to do all the behind-the-dash ducting for the heat/ac system. That was fun Just a couple things left to do and there will be nothing on my truck that doesn't work. Anywho the passenger side kick panel vent is vacuum operated. (Not sure what the technical name for it is, but it lets in air from outside I believe.) If I am not mistaken it gets a vaccum line run from the AC/Heater control unit. If that is correct, then which one do I plug the vacuum line for the vent into? (Pic below) They are labled but incase the pic didnt come out. "1" is far right "2" is middle and "3" is far left. this control unit is an extra that I Just happen to have. The one in my truck has a cap over number 3. So where does the switch take the vaccum from? I'm going to assume that I have to run a line from the motor through the firewall and into the switch. Is that right? Also are there 3 outlets on the switch so that the driver kick panel vent can be vacuum operated too? That would be pretty sweet I might convert the driver's side too. Thanks again for any help.
-Dave-
OneMpg is offline   Reply With Quote
Old 08-25-2003, 08:11 PM   #2
OneMpg
Close up shot
Old 08-25-2003, 08:31 PM   #3
Class of 69
Class of 69's Avatar
vacuum source from engine to #1...vacuum to vent #2. The vacuum to the vent also controls the outside air door under the cowl, and the hot water shut off valve in the heater hose.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-25-2003, 09:04 PM   #4
OneMpg
Thanks much. Also, is there somewhere where I can get the interior air distribution boxes? Basically just the two boxes that route the defrost/deice and the heat/ac. The boxes that I have are a bit worse for wear. I will try painting them but if I can buy them new I'd do that in a sec. Thanks-
-dave-
Old 08-25-2003, 11:34 PM   #5
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Hope this isnt too small.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 08-26-2003, 08:23 AM   #6
racedvl
racedvl's Avatar
Bigger . . . .
racedvl is offline   Reply With Quote
Old 08-26-2003, 01:25 PM   #7
OneMpg
Thanks Just what I needed.
-Dave-
Old 08-26-2003, 05:30 PM   #8
ddsmith
Glowing since 1978
ddsmith's Avatar
OneMpg,
What kind of shape are you looking for from the boxes. I ripped the A/C out of my truck and put in a Old Air unit. I was getting ready to pitch this stuff in the dump. Let me know if I can help.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
