Old 02-22-2015, 08:35 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
What did you get done 2/22//15 edition
We got more parts in and my son and I finally picked up a bed from ScottH for his beater.. My son also picked up a project 85 Monte carlo SS and an 84 parts car All weekend long ive been shifting cars around lol How about you all>
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-22-2015, 08:38 PM   #2
enaberif
Re: What did you get done 2/22//15 edition
Truck is 100% assembled and now its time to burn some rubber and do some adjustments and check any leaks out.
enaberif is offline   Reply With Quote
Old 02-22-2015, 08:45 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
I got the exhaust replaced on my CUCV Saturday but the engine has developed a fuel leak, makes it hard to start. Rain today, couldn't mess with it. Always next weekend, right?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-22-2015, 10:28 PM   #4
natedogg
I sold the sway bar and sway bar brackets off my parts truck to a fellow board member. I had a tough time getting the factory rivets out. It took a grinder, air hammer, air chisel and a torch to get those 30 year old rivets out.
natedogg is offline   Reply With Quote
Old 02-22-2015, 10:33 PM   #5
Slammed84
Slammed84's Avatar
Manged to fill my garage with fumes, and probably woke a few neighbors up around 2:00 am this morning starting my truck with open headers.
Yes there was some drinks involved...
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 02-23-2015, 07:08 AM   #6
S10Fan
Old Heap Driver
Chased issues with my 97 Yukon, Crank Sensor, TPS, and Idle Air Solenoid. Changed the cooling fan switch on my kid's Civic, did about 10 minutes welding on the Model A project.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-23-2015, 09:21 AM   #7
'76 Big Block
FINALLY finished the exhaust on my '76 step side (454)----from headers to tailpipes----all new and shiny (for now)!
It looks (and sounds) so good I want to take it back for another state inspection since I barely passed last time with all the leaks!
'76 Big Block is offline   Reply With Quote
Old 02-23-2015, 09:20 PM   #8
naphtali5725
naphtali5725's Avatar
finally got my engine from the builder... and in the process of getting it installed... running down all the incidentals needed for the install, if the damn snow and ice will go away... good luck to all ya'll with your trucks
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 02-23-2015, 10:28 PM   #9
enaberif
- Yanked the 40 year old tape deck
- Fuel gauge working again
- Vac gauged the motor and steady at 17hg
- Tried to get the vacuum line hooked up but got dark
Old 02-24-2015, 11:12 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
We've been breakin some cold records here lately.
But after some snow Sat it got up too -1C
cleared it,let the dog run a bit,moved my seats further in the garage for now
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-24-2015, 04:40 PM   #11
mattcrp1
mattcrp1's Avatar
Finally got my drive shaft down to the drive-line shop to get it cut for my LS swap. I think I got my temp sender issue figured out only to find out I think I broke my new sender, two steps forward and one back.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-24-2015, 04:53 PM   #12
Shifty One
Shifty One's Avatar
Bought a white front bumper (with brackets) to replace my chrome one with bent brackets. I think the white should look sharp with the white wheels/dog dishes.
