Old 02-22-2015, 11:21 PM   #1
hillbean
Need some help with vacum assisted brakes
Hey everyone thanks to all of your great write ups i started my engine/trans/ps/pb swap and am about to wrap it up just need a lil help from ya all. I pulled the MC/Booster/Prop valve from a 73 Chevy c10 truck and then after deployments and some other stuff i lost the brake lines. Does anyone know what size lines and fittings go from the master cylinder to the prop valve and from the prop valve to the rear brakes. I can post a picture when i get a chance. Ive tried looking everywhere but cant find anything any help is much appreciated.
hillbean is offline   Reply With Quote
Old 02-22-2015, 11:45 PM   #2
vince1
Re: Need some help with vacum assisted brakes
You did say any help so even if it isn't I'll try a bit. I used a 67 master cylinder so don't know if it is the same as yours. Pulled some lines from a junk yard, closest to firewall for front brakes were 1/4", and furthest forward were 3/16" to back brakes that I stepped up to 1/4. I don't know the fitting sizes or if 3/16 or 1/4 was even relevant as you could probably use either size in an appropriate fitting.
You might also try and take your master cylinder and wander off to a car parts shop like O'reilly's? and check out their lines and fittings.
vince1 is offline   Reply With Quote
Old 02-23-2015, 02:23 AM   #3
Captainfab
60-66 Nut
Not all master cylinders are the same in regards to which port is for the front brakes and which port is for the rear brakes. The easiest way to determine which is which, is by the size of the threads in the ports. The 3/16" line is for the front brakes and the 1/4" line is for the rear brakes. The prop valve will have 2 ports on one end for the two 3/16" lines that go to each front caliper. The opposite end will have one port for the 1/4" line that goes to the rear brake hose that drops down to the differential. The two ports on the side of the prop valve are the in ports from the master cylinder.
Old 02-23-2015, 09:53 AM   #4
hillbean
Yeah i have a 3/16 line for the front port and 1/4 line for the rear port the standard fittings are to small for the M/C I think im just gonna grab an adapter and do it that way i was just wondering if there was a specific line size i needed and it sound like I have them. Thanks for the help guys
Old 02-24-2015, 02:16 AM   #5
Captainfab
60-66 Nut
The master cylinder will have threads that are larger than a typical tube nut. In looking up a '73 C10 master cylinder the front brakes have a 9/16"-18 thread and the rear brakes have a 1/2"-20 thread.
Old 02-24-2015, 02:32 PM   #6
61K10
61K10's Avatar
summit racing sells tube nuts for the master, but you have to re-flair the ends of course.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-25-2015, 12:54 AM   #7
hillbean
thanks for the help guys i got it figured out just had to spend an hour at the parts store looking for the fitting for the rear brakes
