rear end swap
Will the rear end out of a 72 c10 swap into my 63 lwb? i Know the 73-87 rears are wider but dont think i have ever read about the 67-72 widths
Re: rear end swap
I used one out of a 71 c10. It was 1.5" wider than my 64 rearend. I think 63 and 64 are the same. The panhard bar will have to be changed.
You can find me on Instagram @neveno_cten Last edited by NevEno; 02-23-2015 at 12:31 PM. |
Re: rear end swap
mid way thru 70 they changed the width . maybe 71? pretty sure it was 70
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: rear end swap
A '71 12 bolt will be 1.5" wider than a '63 to early '70 12 bolt. The '63 and '64 use the longer panhard bar with the mount on the passenger side axle tube. You can use the shorter '65-'72 panhard bar, but you will have to put a slight bend in it at the end that mounts to the frame bracket. Or you could also change the frame bracket to one from a '65-'72
![]() Join Date: Mar 2005
Re: rear end swap
When they went to the 5x5 bolt pattern in 1971, the width increased 1.5". Not sure why they decided to increase the width, but I always assumed that it was in preparation for the redesign in '73 and it was a cost-saving measure.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Never Ending Projects
Re: rear end swap
IIRC it was due to the change to disc brakes up front. This brought the wheels out .75" per side, so they needed to do the same with the rear end, hence it being 1.5" wider.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
| Bookmarks |
