02-23-2015, 12:31 PM | #1 |
Roadtrip!
Rear tow hooks.
Very cold here today so i dug these out in hopes of heping to clarify some things about these rare birds... I see them for sale from time to time and am guessing they are usually not the originals. The first couple pics are from the 69 gmc accessories book. I am sure the one hook is correct. The other is very similar, but not exact.
I am starting this in hopes of getting some clarification so am looking for input, pics or whatever you may want to add.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-23-2015, 12:34 PM | #2 |
Roadtrip!
Re: Rear tow hooks.
More pics...
The instructions are dated 71.
02-23-2015, 10:07 PM | #3 |
Re: Rear tow hooks.
Mine look like yours. I lost my camera. The number on them is 2133367GM22LH on one side and 2133366GM22RH on the other side of each one. They don't have that encircled U and there are other numbers embossed. One has RUA in slightly larger letters near the base next to the bolt hole on the side the hook curls toward. The other has TPS on the side it curls away from, same place by the bolt hole. Those letters are about 1/4" tall
02-24-2015, 10:04 AM | #4 |
Re: Rear tow hooks.
I think it's possible these came from different vendors at some point. yours are certainly GM and so are mine, yet there are differences. Look at the bumper guards. I bought two pair the same day from the dealer. Years later when I removed from the box, one pair had smooth pads and the others had ribs. Up till then I considered the ribbed ones as non-GM.
02-24-2015, 11:46 AM | #5 |
Re: Rear tow hooks.
How big is the hook? It appears larger than the ones available today.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-24-2015, 12:32 PM | #6 |
Re: Rear tow hooks.
You can purchase these rare hooks all day long here:
http://www.clevelandhardware.com/cat...g_devices.html
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
02-24-2015, 10:51 PM | #7 |
Carpe manana
Re: Rear tow hooks.
The footprint is too wide to affix to a frame - the frame has to be widened (as on mine here, last pic: http://67-72chevytrucks.com/vboard/s...4&postcount=37) if one wants the hooks accessible. I suspect these were originally intended for use with larger (ex. C50) rigs.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-24-2015, 11:01 PM | #8 | |||
Roadtrip!
Re: Rear tow hooks.
02-24-2015, 11:05 PM | #9 |
Carpe manana
Re: Rear tow hooks.
I noticed that also and was scratching my head. Seems like you'd encounter the factory holes for the bumper brackets and there's no way you'd be able to make use of a rear bumper once installed in that configuration.
02-24-2015, 11:10 PM | #10 |
SWB 4x4 Collector
Re: Rear tow hooks.
I assume they are instructions for a 3500 1ton chassis that didn't have a factory bumper perhaps? Thus needing a tow point? Also if cab and chassis 157" wheelbase frame, they have taller frame rails. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-24-2015, 11:14 PM | #11 |
SWB 4x4 Collector
Re: Rear tow hooks.
Just read the ad, "for all models". Still my guess is a truck not ordered with a rear bumper, these would be an option for rear tow points for an owner. Also needing the license plate location. Trevor
02-26-2015, 10:52 AM | #12 |
Re: Rear tow hooks.
Rear bumpers were an option on all trucks. You could also get a cab & chassis in all GVWs.
