02-24-2015, 10:55 AM | #1 |
rear leaf springs
So I have a few questions maybe y'all could answer for me. So I have a 1972 chevy 1/2 ton 5 lug. The rear leaf springs are cracked and I'm having a hard time finding a set cause they are 2 1/4" wide was wondering if I could use the standard 2 1/2" ? and or is there another truck or what not I could find a set to work ? Like will a set off a new pickup work ? I'm having a hard time finding a set.
02-25-2015, 12:12 PM | #2 |
Re: rear leaf springs
02-25-2015, 03:48 PM | #3 |
Are you going to lower the truck or is it lowered? Several companies sell 4" drop leafs and are easy to get. 3/4 ton springs will work as well and you could pull the overload and would probably work OK and would be easier to come by. I have the HD leafs on my short bed (4 leaf plus overload instead of 3 and the overload) and it drives fine.
FWIW, most GMC trucks are leaf and most Chevy's are coil, but either can be found either way.
03-01-2015, 01:37 PM | #4 |
I used General Springs with a DJM flip kit. If I knew my stocks were shot or I was going to stay lowered I probably would have gone with drop springs. http://www.generalspringkc.com/Leaf_...972_s/1822.htm
USA made and good price. My experience: http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens Last edited by sKnNyPpY; 03-01-2015 at 01:43 PM. |
