motor mount location
I'm installing a 305sbc/turbo 350 trans in my 53 GMC longbed.I have a mustang 11 suspension .Is there any preference or layout to where the engine sits. I'm going to use block hugger headers. I want to put engine and trans together then install in truck.
Re: motor mount location
stock frame or clip?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Stock frame with Mustang 11 ifs
I have a mustang 2 with stock boxed frame setup and the centerline of my motor mounts ended up above the rear edge of the mustang 2 crossmenber. I bolted my block hugger headers on and centered and positioned the motor and trans combo so everything would clear then welded in my mounts accordingly. I put my motor as low and far back to the firewall as possible which should help handling. I also had the cab on to make sure distributor and valve covers would clear the firewall.
