Old 02-24-2015, 07:51 PM   #1
Gregski
Gregski's Avatar
Fel-Pro Gasket Wet or Dry Muncie SM465 Transmission
how would you put on the Fel-Pro gasket set on the 4spd Muncie SM465 transmission, dry, lube it in transmission fluid, use RTV, gasket adhesive?
please advise
Gregski is offline   Reply With Quote
Old 02-24-2015, 09:11 PM   #2
cerial
cerial's Avatar
Re: Fel-Pro Gasket Wet or Dry Muncie SM465 Transmission
I used loctight red gasket maker on 2 465's without a leak. Stuff is expensive but works great.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 02-24-2015, 09:43 PM   #3
mrolds88
I use a very thin coating of gasket sealer. Meaning you could read through it. That accomplishes 2 things. First if there are any surface flaws that the gasket itself wont take care of, it will fill. And second, if I have to remove it later, it will come apart easier.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-24-2015, 10:04 PM   #4
hatzie
Moderator
hatzie's Avatar
Spray Permatex or Loctite High-Tack on the gaskets and wait 5 minutes. Stick em on and bolt em up... It's just there to keep the gaskets from sliding round as you put in the bolts.
Honestly you could use some stiff tacky grease and a small paint brush in most cases. As long as the gasket is stuck to the part long enough to get the bolts in and tight you're fine. The side covers are small enough I'd just put em on with dry gaskets.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-24-2015, 10:09 PM   #5
Titomars
Titomars's Avatar
spray on Permatex red hi-tack is all I ever use. Never had a leak or a comeback from using it.
Spray it on both sides of the gasket. I do 2 coats let each coat set up for 5 to 10 minutes then slap it together.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 02-25-2015, 11:56 AM   #6
Bigstevex4
Bigstevex4's Avatar
I like a soft gasket sealant High tack is more for holding it in place. There is a gray gasket maker we get from Ford T44 for Navistar. when i worked on Heavy eguipment Komatsu had same thing in there tube. like JR6 sure bet its all made by same company.
old permatex worked great just a pain in Butt after it hardened. that black silicon Permatex has is good.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 02-25-2015, 12:13 PM   #7
Gregski
Gregski's Avatar
thank you very much fellas, went with the Permatex High Tack Spray-A-Gasket Sealant
man getting that top lid back on that transmission was a bear, I had to do that half way in reverse bit to get her on
